how to release belt tensioner???
i am having the worst time in the world trying to release the tension on the serpentine belt... some on please help me out! be very specific if you can.. i have read every thread on here about this and i still cant do it! pics would be nice too also, any special tools? do i need tamper resistant torx bits? thanks in advance for any help!
Cookierx1 (01-19-2022)
Re: how to release belt tensioner???
Need an E10 Torx, mine was not a "security" type. (a 3/8" drive bar works well)
The tensioner pulley is #3 in the diagram. Using the E10 on the pulley give it a 1/8 to a1/4 of a turn and the tension will release.
While the tension is released slip belt off/on. (without pinching yourself )
CROSSFIRERUSH (05-13-2024)
Originally Posted by HyprLtH20
i loosened the bolt in the center of the tensioner pully but nothing happened... seriously i need help.. is it so simple that i am looking straight through it?
(rotate as if tightening)
which way and direction does the pulley "swing"? i just dont get why i cant do this.. its so simple n every other car ive worked on.
i tightened the bolt up and continued to rotate as if tightening but nothing happened. maybe im not doing the right bolt? is it the bolt that holds the pullley on?
What are you using?
Pulley will swing towards the crank pully.
Up I believe - it should be clear looking at it - one way would tighten the belt other would loosen.
Sorry only did this once.
There is nothing that needed to be done first - just release tension and remove belt. Sorry you are having such a time with this.
but if i rotate it counter clockwise then the bolt comes loose.. ? is it a different movement than a normal ratchet movement? i bought a 3 foot long steel bar to get more leverage but still cant get it to do what i want.. if i go clockwise i get nothing but a very tight bolt.. if i go counter clockwise i get a loose bolt..
ok so i finally got it! anthony at tvt helped me to understand.. it isnt the torx bolt that holds the pully on.. it is a fixed "nut" that is attatched to the left of the tensioner pulley. you can use your lug wrench to release it. push it counter clockwise with a bit of force and it will come.
Hi Guys,
I am new owner of an '04 Crossfire. I bought a new serpentine belt to keep in the car as a spare or until the original needs replaced. With 22K on it, the belt seems to be in good shape yet.
After reading this thread, I couldn't believe all the posting about releasing tension on this belt that seems so easy when looking at it. This is my first FOREIGN built car so I figured I better check my self. That pulley bolt head size is a T50H bit. Actually I refer to it as a T50 Tamper Proof bit. Turning the bolt clockwise only caused the belt to be tighter. Turning the bolt counter-clockwise only loosened the bolt. I saw no jam nut as previous mentioned.
After further investigation with a mirror I found the answer. There is a protruding hex casted into the tensioner just below the belt where you can't see it. New one on me! Using a deep 17mm socket and ratchet, the tensioner can moved. The longer the ratchet handle, the better. No pry bars needed.
Did MB use more than one type of tensioner on this engine?
Here is a pic of what I found on mine to help others. James
The following 2 users liked this post by James1549:
CROSSFIRERUSH (05-13-2024),
M60A3Driver (09-26-2023)
That is nothing like the pulley on the SRT.
The center pulley torx is "male". Simply put the E10 on it and turn and the tension is released and the belt comes off.
Now I see why what I was explaining was not working.
