Alarm fault
Can anyone help
I had a problem with the alarm going off for no reason. The dealer had it in and charged the battery saying it was slightly down. I took no chances and changed the battery. I still have the same problem. Iv just noticed that the little red light in the roof near the mirror is staying on after the engine is switched off. Pressing it does nothing,it just stays on. The only time it goes out is when the engine is running. May be this is the reason for the battery drain. Does anyone know how to reset the alarm or is this some thing else? Help Jon |
Re: Alarm fault
Hi Jon Sadly no idea re the alarm fault. Did the main dealer have any thoughts re the problem? Maybe contact another main Chysler garage and ask the question again.
Hope to touch base soon. Cheers Ken.:) |
Re: Alarm fault
Hope to touch base soon. Cheers Ken.:) If no joy here. I will call another dealer next week. Catch up with you soon. Jon |
Re: Alarm fault
Hi Jon,
Isn't the little red light supposed to go out after a few seconds, indicating that the device (for remotely opening garage door or electric gates) is ready to use. There is something in the handbook about setting it up I think. The light is very small (like the flashing flashing alarm light) and shouldnt drain the battery. If its faulty and staying on; it could interfere with the alarm, so njust disconect it by prizing off the panel and pulling the wires, and see if that cracks it! Good luck! |
Re: Alarm fault
Hi Steve. How's things with you?
Its this little red light that's staying on. I think the ones in front of that are the garage door opening one? http://farm4.static.flickr.com/3093/...4432daf3_m.jpg Jon |
Re: Alarm fault
Hi Jon,
Its a strange one, I cant think what could cause it to stay on, unless there is some kind of reset you can do. Have you checke3d out the hand book yet? I will check it out on mine when I get the car back, its having major surgery at the moment and expect to get it back later this week! Cheers, Steve |
Re: Alarm fault
Hi Jon,
Its a strange one, I cant think what could cause it to stay on, unless there is some kind of reset you can do. Have you checke3d out the hand book yet? I will check it out on mine when I get the car back, its having major surgery at the moment and expect to get it back later this week! Cheers, Steve I forgot about yours. How's that getting on? Just to rub a bit of salt in the wound, it looks like some one has thrown a brick at mine. I now have two dents in the roof to repair. Great!!!!!!!! I will take a look in my hand today. Thanks Jon |
Re: Alarm fault
Jon, Alarm fault and roof damage, your not having any luck with the Crossfire of late.
Cheers Ken.:) |
Re: Alarm fault
Jon, Alarm fault and roof damage, your not have any luck with the Crossfire of late.
Cheers Ken.:) They say it comes in three's :( :( :confused: Jon |
Re: Alarm fault
Jon..Don't panic, as the first dent in roof..make the three..so thats the end of the bad luck with the Xfire..( I hope)
Cheers Ken.:) |
Re: Alarm fault
Originally Posted by The bodyman
Hi Steve.
I forgot about yours. How's that getting on? Just to rub a bit of salt in the wound, it looks like some one has thrown a brick at mine. I now have two dents in the roof to repair. Great!!!!!!!! I will take a look in my hand today. Thanks Jon Cheers - Steve |
