Can Fog lights be added to base models?
Hi, Can the fog lights simply be added to the base model, that didn't come with them installed or do you need to wire everything in? I want to add factory fog lights to my base roadster, do not want to use aftermarket.
Thanks.
Thanks.
some other base owners have done so.
you can add the factory fog lamp assemblies... however you will need to run you own wiring (not pre-wired from the factory). and the factory switch will work once wired.
Originally Posted by ShadyXfire05
Thanks, do I need a relay too? I saw the fuse holder in the fuse box, thanks.
Adrian_X
Nov 9, 2017 08:49 AM
northwest_crossfire
May 30, 2016 05:19 PM
KwehCat
Jul 16, 2015 04:48 PM
