LED Tail Lamp Question
Old Dec 2, 2007 | 02:27 PM
amcordo's Avatar
Question LED Tail Lamp Question
Hello all!
I'm new to the forum after buying a Crossfire just two months ago! I read through a lot of the old postings and can't wait to start performing some of the mods. I've installed LED tail lamps on my Crossfire, however I didn't put in resistors. While both lamps light up as parking lights, only one of them activates when I hit the breaks. I assume I need to install resistors so I bought a pair. What I don't know is which of the three wires should I be bridging with the resistor? Black & Red, or Black & Green? Anyone have input?
PS: for anyone curious the LED lamps I got were 18-LED 24.5mm wide and fit fine. They are the least bright I would suggest and may upgrade to brighter pair. Further, they came with clear plastic caps over the LED circuitry that I would strongly suggest removing if anyone purchases a similar pair. The covers tend to pop off and then you have to take the whole tailout out and shake it upside-down to get the cover back out. After measuring it appears (untested) that up to a 26mm wide lamp would fit into the socket.
Thank you!
Anthony
Old Dec 4, 2007 | 07:34 AM
BCThomas's Avatar
Default Re: LED Tail Lamp Question
When you figure it out, share I have put LED's in the front running/parking lamps and still need to put in some resistors so my bulb out indicator goes away.
Old Dec 4, 2007 | 07:43 AM
CrossfireLTD's Avatar
Cool Re: LED Tail Lamp Question
Congrats & Welcome to the Forum!!!
Check your bulb fitment/fitting, you only need resistors to eliminate the "bulb out" indicator and the rapid flashing issue. I have switched out all of my stock bulbs to LED's with out any problems, other than the "bulb out" light remaining on.
Old Dec 4, 2007 | 02:56 PM
amcordo's Avatar
That's what I like to hear! What LED light did you use for tail lights? It could be that I got a cruddy brand. Do you have a link?
Old Dec 6, 2007 | 08:43 AM
jonnyb0ii's Avatar
i don't understand these resistors. is it like a plug or something? where can i order them online?
Old Dec 6, 2007 | 09:30 AM
maxcichon's Avatar
I've seen them on www.superlumination.com. They're called load resistors and they are just that-ceramic resistors with some connectors as a"kit".
Best of luck,
Max
Valk
Jul 12, 2021 09:49 PM
eikon
Sep 9, 2019 10:16 PM
Mike OD
Sep 23, 2016 07:00 AM
jimf
Oct 10, 2015 10:22 AM
AlbertFattal
Sep 24, 2015 05:03 AM
