No lights
Old Nov 8, 2012 | 10:48 PM
milesalm's Avatar
Default No lights
I had HID's put in the other day and today my low beams does not seem to work. fogs work fine, and high beams work fine but low beams does not come on. could it be my headlight control module
Old Nov 9, 2012 | 01:47 PM
Default Re: No lights
Did you check the fuses?
I assume that they worked just after you put them in.
Old Nov 9, 2012 | 02:10 PM
milesalm's Avatar
Yes fuse are fine, for some stange reason I got home and a few minutes late they work fine I'm thinking it's the ballast and the location maybe they for to hot
Old Nov 9, 2012 | 02:26 PM
Selbyl's Avatar
Heat is the enemy of electronics so that may be it.
Also make sure you don't have anything wired back asswards and you have a solid ground connection. Also HID bulbs take a little time to warm up so it's possible they just hadn't warmed up.
Old Nov 9, 2012 | 02:44 PM
I mounted my ballasts on the frame UNDER each headlight and used that white thermal conductive gunk made for PC CPU sockets between them and the frame .....
2004_
Jul 9, 2025 12:39 AM
jgreen
106
Sep 18, 2017 11:46 PM
xfClifford
27
Nov 10, 2015 10:08 PM
KwehCat
Jul 16, 2015 04:48 PM
