Gas door torn off
Old Mar 1, 2013 | 07:45 PM
Parallel Ice's Avatar
Default Gas door torn off
Yep; you are readin' it right.
Some low life ripped my gas door off; so now I get to fix it.
The plastic assembly is still good, just the panel came off. There seems to be a caulk type of adhesive on it, but I am not sure if that is from the factory or if it is a previous fix.
Any suggestions on what to use to put the panel back on? I figured gorilla glue from HD would do the trick.
Old Mar 5, 2013 | 10:29 AM
Default Re: Gas door torn off
Make sure the latching assembly is still working properly before you remount it so that you can fill the tank whenever you want. Would not help a bit if the door doesn't open and you gorilla glue it shut, would it?
Old Mar 14, 2013 | 08:04 PM
Haha; good advice
Gorilla glue worked wonderfully. I made sure to use two clamps to keep even pressure; after that, a little time with the exacto blade to remove the excess and I was good to go!
Product approved!
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Billy22Bob
Sep 28, 2015 08:08 PM
jaesa
Sep 7, 2015 01:50 PM
MickeyNasty
Sep 6, 2015 08:29 PM
