Researching... need some help from N/A owner
Old Apr 30, 2013 | 02:39 PM
JHM2K's Avatar
Default Researching... need some help from N/A owner
I'm communicating with Webasto, trying to get some info on the wing motor and limit switches. I fear this is going to be an issue for many N/A owners as time passes... and since the wing is serviced as an entire assembly, it might be advantageous to know where to get a spare motor (save some $$$).
Can someone look for any stampings/markings on the rear drive assembly (underneath)? There's a Webasto tag with numbers, a photo of that would be brilliant.
Thank you,
Old Apr 30, 2013 | 03:14 PM
Default Re: Researching... need some help from N/A owner
I'll see if I can get the info on the roadster one.
Might be different from the coupe, I don't know.
Old Apr 30, 2013 | 03:35 PM
JHM2K's Avatar
Thanks man. It should be visible from the underside, I doubt you'd even have to remove the assembly (unless you have to remove that annoying bracket).
Cheers,
Old Apr 30, 2013 | 06:42 PM
Was able to remove the motor end-bracket and spin the motor around without unmounting anything.
However, no data on the other side, all there is, is on the yellow label, and that has no part numbers or manufacturer stamps.
Sorry.
Old Apr 30, 2013 | 08:39 PM
JHM2K's Avatar
Sorry.
No worries my friend. The motor likely won't have anything on it, as it is part of the Webasto assembly (plate, gears, arms, motor, everything). I certainly appreciate the effort.
The label/part number I'm looking for should be in plain view. See attached photo...
Old May 8, 2013 | 11:24 PM
JHM2K's Avatar
Bump, for posterity's sake.
Old May 9, 2013 | 12:21 AM
bjames's Avatar
Don't understand the writing but here is what is on the label:
Webasto ZB Ant.Heckspoiler
ZH29
Kundennr : A193 750 00 60
Identnr : 1810019D
Lebenslauf : 24
Werkernr : 18
Datum/Zeit: 01 06.2004 /14:51
Some of the letters are faded on the title lines but I copied what I could see. The numbers are correct.
Old May 9, 2013 | 12:40 AM
JHM2K's Avatar
ZH29
Identnr : 1810019D
Lebenslauf : 24
Werkernr : 18
Sweet! I'll send that to Erin at Webasto tomorrow and see what she says. ZH29 is the model that Webasto assigns (the build program... ZH29 = Chrysler Crossfire). I'm thinking our number of choice is 1810019D. I gave her the A193 number, and no dice.
Datum/Zeit will help narrow down the dates to search for. The only bad thing is most info is purged after seven years (from a service parts perspective). But we'll see.
Many thanks,
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
o55ie18
Oct 5, 2015 05:50 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
JEFASOLD
Sep 28, 2015 12:10 PM
