Removing/replacing OEM Chrysler badges?
Old Mar 24, 2014 | 03:38 PM
HOT FIYA's Avatar
Default Removing/replacing OEM Chrysler badges?
Hey everyone. I recently purchased a set of new OEM Chrysler badges to replace the heavily faded ones that came on the car upon purchasing it. I looked at some aftermarket options/overlays but I wasn't sold on any of them and decided that i'd rather simply get new OEM badges.
Anywho, the badges recently came in the mail and i'm just wondering if anyone has replaced these before and if so what the easiest way to do it is? My biggest concern is damaging the chrome wings. My best guess was to use a metal "pick" tool to pop them out. Also, does anyone know how these badges are affixed? (glue, double sided ahesive, clip?)
Any/all feedback is greatly appreciated! Also, below is a picture of the badges I am referring to.
Old Mar 24, 2014 | 04:05 PM
lildaddym's Avatar
Default Re: Removing/replacing OEM Chrysler badges?
What's the P/N on those badges?
Old Mar 24, 2014 | 04:52 PM
HOT FIYA's Avatar
I'm not sure. I can check the little bags they came in when I get home to see if there is a part number. I actually stumbled across these on Amazon after a Google search directed me there. I couldn't find them on any of the OEM Chrysler parts websites. The only thing I could find was the entire wing badge assembly which I would guess also includes the emblem itself. But needless to say I didn't want to shell out a ton of money for the entire assmembly when I only needed the badges. When I purchased them on Amazon they were the only two left in stock.
Old Mar 24, 2014 | 06:06 PM
S. Artee's Avatar
Search for the 300, should be exactly the same badge up to 2010—11.
They're applied with double-sided adhesive.
Old Mar 24, 2014 | 08:23 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
I would try heating up the old one with a blow dryer or heat gun to soften the adhesive before prying away.......and use a hotel door pass as a prying tool.
Old Mar 24, 2014 | 08:47 PM
Abaton6's Avatar
I've used dental floss to remove letters , badges. Works pretty slick. FWIW.
Old Mar 24, 2014 | 09:25 PM
HOT FIYA's Avatar
Thanks everyone.
My rear hatch is already de-badged (removed the Crossfire letters & SRT-6 badge). I'm just talking specifically about the Chrysler badges. Did you also use dental floss to pop those badges out of the chrome wings?
Old Mar 24, 2014 | 10:19 PM
andrew's Avatar
-C-I-C-C-I Associate Member
~ they are most likely held on by a rubberized glue type product from the factory.
i would try to remove the main wings themselves and determine if there is a small hole or two on the backside to press the chrysler badge out versus prying it out from the front side. heating up the badge will also aid in the removal or breakdown of the adhesive... hope this help.
Old Mar 24, 2014 | 10:54 PM
S. Artee's Avatar
Default
Badge is recessed, makes floss kinda tough. Metal picks are probably a best bet.
Old Mar 24, 2014 | 11:03 PM
Abaton6's Avatar
Originally Posted by HOT FIYA
Thanks everyone.
No HF, just the ones attached with tape. Work it like a saw, comes right off.
Old Mar 26, 2014 | 01:01 AM
HOT FIYA's Avatar
I've already removed the "Crossfire" & "SRT-6" badges. As far as shaving badges goes, that's easy peasey. I'm just looking for an easy way to remove the oval Chrysler badges from the chrome wings without damaging them. But thanks for yours input regardless.
Old Mar 26, 2014 | 09:29 AM
S. Artee's Avatar
Default
Again... You might also want to heat them as you pry.
Old Mar 26, 2014 | 04:11 PM
HOT FIYA's Avatar
I have a heat gun so I was planning on using it when prying them out.
Old May 10, 2015 | 06:38 PM
mss400's Avatar
Are front and rear badges (not the wings) the same or different?
Old May 10, 2015 | 08:28 PM
JEFASOLD's Avatar
They look the same but are a different size, the rear is smaller.
Old May 12, 2015 | 10:10 AM
HOT FIYA's Avatar
Also it's worth adding that the Chrysler badge can be removed from the wing emblem whereas the rear badge cannot. In other words, you can replace just the Chrysler oval up front whereas in the rear you have to replace the whole assembly (wing emblem + Chrysler oval).
Old Jan 15, 2018 | 01:00 PM
sedavigo@gmail.com's Avatar
so you are telling me that I can replace both emblems front and back with the same that are used for the Chrysler 300 2010??? This is easy to find.
mattnelson71
Jul 28, 2015 08:59 PM
leaddog2015
Jul 24, 2015 10:13 PM
cjfine
Jul 20, 2015 11:58 PM
ZX2 Nick
Jul 15, 2015 08:49 PM
tom2112
Jul 8, 2015 08:13 PM
