Install Mopar Nose Mask Front Bumper
Old Jul 24, 2015 | 08:16 AM
autumnmass's Avatar
Default Install Mopar Nose Mask Front Bumper
I purchased a nose mask for my 2007 Roadster however it came with no instructions. It is a Mopar one (w pieces w/license plate opening). When I try to put the hood piece on it seems to be a little short (even the hooks (belt) isn't too long. Not sure where you hook it onto. If anyone has one could you explain how to fit them on? Thank you for your help, Dyan
Old Jul 24, 2015 | 12:29 PM
csteve0355's Avatar
Default Re: Install Mopar Nose Mask Front Bumper
https://www.crossfireforum.org/forum...structions.pdf
Here you go
Old Jul 24, 2015 | 01:37 PM
autumnmass's Avatar
Thanks Steve, appreciate you sending the instructions. dyan
Old Jul 30, 2015 | 11:09 AM
Hindin's Avatar
Dyan - It helps a lot if the nose mask is warm, either from the sun or in the dryer prior to installation. I used 3M clear protective film where the mask clips inside the wheel well on the fenders' edges. The two clips on the upper binding can get stretched and located on the back edge of the frame directly in front of the radiator to not interfere with the hood latch.
Old Jul 30, 2015 | 01:06 PM
autumnmass's Avatar
Awesome, thank you for that tip, I didn't think of letting it sit in the sum to make it more flexible.
PNA
Nov 12, 2020 04:44 PM
Jul 29, 2015 06:13 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
rmcdaniel12
Jul 21, 2015 11:35 PM
shawnwatson9493
Jul 9, 2015 11:47 PM
