Fog light restoration?
Has anyone had any luck in restoring the glass fog light lens? I see I am not the only one with pitted lens on the glass fog lights. I would like to get mine back in shape without spending $400 bucks.
What about this? James |
Re: Fog light restoration?
Car-Part.com--Used Auto Parts Market used foglamps
I removed and cleaned the inside of my foglamps this removed that hazy film and they look a lot better. I haven't tried to polish out the scratches hope the video helps. car-parts .com prices are reasonable, I have used them on other parts |
I used the 3M kit for this. Bought it from the local auto parts store. It worked fantastic. All you need is a drill motor.
Meguires has a kit as well Warning, you must tape off the area around the lens, or risk damaging your paint. |
David M, are you confusing this with HEADLIGHT restoration ?
I wasn't aware that 2M had a kit for the GLASS in the fog lights. |
(Post 910672)
I thinking maybe something to fill the pits... any ideas?
I had bought a fog light from eBay really cheap and it was terribly pitted.
I got some glass polishing stuff from Amazon that was advertised to fix pitted windshields. 2 hours later and almost burning out my drill, I had hardly made a difference. I sold the light as-is. |
(Post 910693)
I got some glass polishing stuff from Amazon that was advertised to fix pitted windshields. 2 hours later and almost burning out my drill, I had hardly made a difference. I sold the light as-is. You guys must enter the Baja desert race.:p |
Maybe it’s time I put some protection on my fogs |
My mistake. Glass is a pretty hard substance compared to plastic. The only thing I can think that might work is a clear (two part) LPU paint. Basically the same clear coat paint you find over the base coat paint on your car.
Originally Posted by David M
(Post 910714)
Get a spare set while you can. |
Maybe silicon sealant on a sacrificial thin sheet of clear plastic?
Would expel film hide the pitting?
