Dome light twist sockets?
Old Aug 25, 2022 | 12:02 PM
Lightbulb Dome light twist sockets?
I found these for my dome light twist sockets (https://www.ebay.com/itm/26205636624...3ABFBM2vONhtVg). Received them today (made sure the physical size was correct before ordering), BUT upon receiving them found only one SMALL difference that seems to not make a difference. The 'cam' locks are NOT 90 degrees offset off the terminals like the OEM's, they 'turn' a little further to the molded lock position. This makes the terminals (if fully locked) off the metal strip that is carrying the voltage. I have found IF you just twist them until the socket terminal 'bump' clicks between the metal strip and the plastic frame, they stay in place and work fine. Doing this, the 'cam' lock is about 1/2 way into its 'turn-to-lock' position. It is working for me, it is tight enough to not 'bump loose', and they were priced for 10 each with free shipping. Maybe something to consider for the membership? Good luck!
Old Aug 25, 2022 | 01:14 PM
F4celess's Avatar
Default Re: Dome light twist sockets?
Excellent reference to an alternative product. Might order a set just as a backup.
Had the pleasure of dealing with these dome twist sockets the other day, when I was removing / re-fitting the Dome light, for the Headliner replacement!
Pdxcrossfire
Aug 7, 2021 10:09 AM
chrisificti0n
May 5, 2013 09:21 PM
chrisificti0n
Mar 16, 2013 04:22 PM
xscape
Jun 3, 2010 11:32 PM
downwardspiral
Feb 21, 2008 04:37 PM
