Seat wire help
Old Jan 7, 2010 | 09:02 PM
cassidyrj1's Avatar
Default Seat wire help
Hey guys I bought some aftermarket seats with my christmas money. Now I disconnected my battery because I read the you will get some airbag light on if you unplug the seats with the battery still connected. I also read that to fix this is to take out the pressure pad and put it into the aftermarket seat. I really would like to not take apart the factory seats. Is there anyway to get around this maybe wire in some switch or something? The other problem is the seatbelt has a wire coming from it. This must be for that ding it makes when you dont buckle. Now if you got around the pressure pad would you need that wire to the buckle?
Old Jan 7, 2010 | 10:04 PM
ZORRO's Avatar
Default Re: Seat wire help
This is my best guess. Do not bet your life on it!
There is no pressure pad in the Crossfire seats. At least not that I could find in the manual. They have what Chrysler calls a simulated pressure sensor or something like that. As far as I can tell what you need to do is use the original seat belt buckles. Under the seat you will find a wire that runs from under the carpet to the seat bottom. If you follow it from where it plugs into the seat it will lead you to the buckle mounted to the seat base. I believe that if you make sure that you are still making this circuit you will get no warning light. I do not know if your airbags will still work. I took the seat out of my car and drove around with the belt hooked up this way (I was able to just plug this together) and got no light. I think that the car tells if someone is in the seat is by whether the set belt is buckled and by whether the belt on at least the passenger side is extended.
Before I did this I put a weight on my passenger seat and it did not give me the seatbelt warning sound or light. That is way I tried this. Try your car and make sure it is the same. Simple huh I still have my stock seats in!
Old Jan 7, 2010 | 10:30 PM
cassidyrj1's Avatar
There has got to be somekind of pressure pad. When I have my car on and im sitting in it doing some work it starts to ding. When im out side of my car with it on it does not ding. Thats why im thinking there is a pressure pad.
Old Jan 8, 2010 | 11:41 AM
ZORRO's Avatar
Try buckling your seatbelt when you are not in the car and see if it stops dinging. These are just ideas from someone who has been beating his head against the same wall. Good luck.
Old Jan 8, 2010 | 01:30 PM
cassidyrj1's Avatar
Haha well this morning I looked into the wiring diagrams and the connections. I found no pressure pad. I have the seat belt buckles on the new seats. Now I need to make a seat bracket for them.
Old Jan 8, 2010 | 02:13 PM
ZORRO's Avatar
When you make the brackets, please post some pics.
Old Jan 9, 2010 | 07:34 PM
cassidyrj1's Avatar
Ok well I got the brackets made today which were really easy to make. I painted them about a hour ago so im going to let them dry overnight and will have pictures tomorrow.
Old Jan 10, 2010 | 03:19 PM
cassidyrj1's Avatar
Haha well this is the last edit here is the new seat next to the old seat.
Valk
Jul 12, 2021 09:49 PM
steps
Apr 26, 2016 06:21 PM
Sep 28, 2015 07:40 PM
steps
Sep 19, 2015 10:43 PM
jaesa
Sep 7, 2015 01:50 PM
