Silver radio knobs?
Old Aug 9, 2010 | 04:38 PM
Default Silver radio *****?
I thought my radio ***** were getting dirty but turned out the silver is wearing off or turning color. Besides buying new ones, if available seperate, anyone have an easy fix to make them look new again? I figured silver paint would just wear or flake off.
James
Old Aug 9, 2010 | 04:48 PM
Default Re: Silver radio *****?
James
I have a solution, radio ***** that are dirty do not bother me and mine are like new so why not swap cars?
You do like black Limiteds I hope.
I heard you can buy the ***** from Becker in the States.
http://www.beckerautosound.com/parts/index_model.html
Old Aug 9, 2010 | 06:42 PM
I've been thinking about using a spray paint for plastics.
Should have grabbed up some of those free ones CoupeGirl was giving away.
Old Aug 9, 2010 | 08:21 PM
bluecoupe's Avatar
***** from Becker are $23 and change a pair and the paint will wear off again no doubt. I've found a supplier of spray paint for rubber surfaces. They can custom match the colour however will be about the same price as new ***** from Becker. The up side is I'd have enough paint for 100's of *****. (OK, here it comes....................)
Old Aug 9, 2010 | 08:42 PM
I do not need grey paint for mine, I'm old and ......
Old Aug 9, 2010 | 08:46 PM
bluecoupe's Avatar
I can always count on you Dave.
Old Aug 9, 2010 | 09:07 PM
maxcichon's Avatar
Rustoleum Silver. Regular ol' spraypaint. It won't melt the plastic. Trust me on this.
Clearcoat. 3 coats.
Old Aug 9, 2010 | 09:54 PM
IBLUBYU's Avatar
Clearcoat. 3 coats.
OK .... I'd like to try this .... do the ***** just pull off ... and what would one use to try to clean any oiliness on the *****, from the fingers, before painting. Maybe just alcohol?
Old Aug 9, 2010 | 10:00 PM
Yes the ***** just pull off. I had mine off trying to clean them.
Tomorrow I will try the paint process.
Thanks for the help. James
Old Aug 9, 2010 | 11:22 PM
maxcichon's Avatar
Isopropyl (rubbing) alcohol.
Old Aug 10, 2010 | 10:41 AM
IBLUBYU's Avatar
Clearcoat. 3 coats.
***** painted and clearcoated as above .... last coat drying as I type ....
LOOKING GREAT
EDIT: After drying I had some left over key fob decals from ANDREW, and stuck them on the *****. They say AMG and are black, and seem to blend well with the other black on the dash. I don't know how to post pics, but I'll try .... I like them
Old Aug 10, 2010 | 12:01 PM
maxcichon's Avatar
LOOKING GREAT
Pics when you are done?
Old Aug 10, 2010 | 03:16 PM
vpats's Avatar
might consider: spraying the ***** with primer, then the color silver you wish, then spray them with a clear coat.
I've done several pieces of plastic using this process, some paints will really screw up plastic without the primer on it first.
I have noticed a bit of "yellowing" on my ***** also.
Old Aug 10, 2010 | 03:29 PM
acrispy1's Avatar
I actually replaced mine with a set that I bought off of someone on here, he was making them for a while I just can't remember who. When I get a chance I'll take some pics.
Old Aug 10, 2010 | 04:36 PM
Took the ***** with me to work. I used two 1/4" bolts stuck through a piece of cardboard and loosely screwed the ***** on to them. Cleaned very well with adhesive cleaner. Two light coats of epoxy primer. Then two coats of silver. No rustoleum, couldn't find any. Throughout the course of the day, I probably put 5/6 coats of Duplicolor wheel clear on them about an hour apart. I already had the car in the garage before I thought about pics. The color matches nearly perfect although the pics don't show that. Once the shine wears down some, it should be a perfect match. Time will tell how they will hold up.
Old Aug 10, 2010 | 04:49 PM
maxcichon's Avatar
Looks great. I bet they will hold up better than the OEM coats. More of them!
I guess satin clear might have matched the finish better. Oh, well...
Old Aug 16, 2010 | 04:50 PM
Warning and Update:
Once you have your newly painted ***** pushed on, Do NOT try to remove them ever again! I took one off to show it, and the paint checked when I tried to squeeze and pull it off.
Removed all paint and did it over again.
James
Old Aug 16, 2010 | 04:55 PM
HyprLtH20's Avatar
www.CustomCrossfire.com
where did you find a close match to the silver?
Valk
Jul 12, 2021 09:49 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Sterling57
Apr 11, 2016 06:11 PM
Mackel
Sep 29, 2015 02:41 PM
Selbyl
Sep 26, 2015 04:15 AM
