dim lighting
Old Aug 14, 2010 | 10:31 PM
bluemax's Avatar
Default dim lighting
the lights at the a/c control area panel only, seemed to dim to the extent that it is difficult to read. could a light behind the panel have burned out? if so, is it difficult to replace?
Old Aug 20, 2010 | 12:16 AM
Lennex3's Avatar
Default Re: dim lighting
I had a similar problem with the overhead light, turned out that the metal connectors were loose, a quick fix. It could be something similar for you though I haven't dug that deeply into my cars interior (stopped at the CD player, never got as high as the ac controls.)
As for replacing, to save money "I" would do it myself. You first need to remove the paneling around the shifter (can be popped out with gentle flathead leverage) and you then want to remove the 4 screws (right under the ashtray/ lighter) the HARD part is getting the CD player out. If you have the keys to do so, lucky you, if not, Ive found that jigsaw blades can work... somewhat...
Everything else should pop out after that...
PNA
Aug 30, 2024 02:06 PM
PNA
Nov 12, 2020 04:44 PM
xfClifford
27
Nov 10, 2015 10:08 PM
pioneer4x4
Sep 12, 2015 11:13 AM
KwehCat
Jul 16, 2015 04:48 PM
