A/C problem. Clutch engages, but no cold air.
Old Aug 29, 2010 | 02:29 PM
maxcichon's Avatar
Default A/C problem. Clutch engages, but no cold air.
Self explanatory?
Everything seems correct and all fuses are fine. Blower blows, heat works. Ambient air or hot air only. At rest or 80 mph.
Just no cold air.
Dealer time? Any one else?
Old Aug 29, 2010 | 02:37 PM
kingkub57's Avatar
Default Re: A/C problem. Clutch engages, but no cold air.
I have seen where the a/c compressor still engages but does not get cold, it was a bad compressor where the pressures are equeling out, you mave also have a restiction within the system itself, you will need gauges to see this though.I,m sure someone else will chime in as well with more info.
Old Aug 29, 2010 | 06:39 PM
waldig's Avatar
Talking Re: A/C problem. Clutch engages, but no cold air.
Throw a gauge on the suction side of the compressor to see if the compressor is pumping or not. They ususally fail with noise, so Iam gonna guess that the charge is lost. Gauges are not costly. Woody.
Old Aug 30, 2010 | 08:27 AM
maxcichon's Avatar
Thanks, bud. But it's under warranty and I'm not learning a new trade at my age!
But since you mention it when the clutch engages there is NO noticeable change in RPM or load. None. It's like the shaft is sheared off inside the compressor.
Go figure!
Valk
Jul 12, 2021 09:49 PM
Mackel
Oct 16, 2015 09:03 AM
jimf
Oct 10, 2015 10:22 AM
Abaton6
Sep 24, 2015 10:14 PM
BEATv1
Sep 10, 2015 12:58 PM
