Need help with C-Pillars!
Old Apr 23, 2011 | 05:59 PM
helma74's Avatar
Default Need help with C-Pillars!
I put in a new headliner and I have everything in but I can't get the rear c pillars to line up without busting the clips because I can't see to line them up! I've been at it for a couple hours help would be much appreciated.
Old Apr 23, 2011 | 07:16 PM
Moparrbust's Avatar
Default Re: Need help with C-Pillars!
Those panels are the worst design and hardest to install on any car I have ever worked on(and I've worked on pretty much every exotic and high end car built in the last ten years). I took mine off about a year ago and after breaking every clip on both panels trying to get them back in place I ended up throwing them on a shelf in my garage(and that's where they are still sitting).
Old Apr 23, 2011 | 08:03 PM
old man's Avatar
had the same problem when i redid my headliner whent with a black headliner an painted all pillar covers in black what i did was drill a hole in the c pillar an put a screw in it to hold it in place
Old Apr 23, 2011 | 09:13 PM
When a pro bodyman tells you this, you know you are in for trouble....good luck...
Old Apr 23, 2011 | 09:21 PM
helma74's Avatar
Yeah I was debating drilling a hole and screwing it in. I'm not to keen on leaving them down as the rear is where my headliner started to fall to begin with. How many screw did you use and where?
Old Apr 23, 2011 | 10:18 PM
JimmySkullz's Avatar
Takes patience, I took mine off and painted them, took forever to get back on, the stupid clips break, dont line up etc.. I ended up with new clips and a heat gun , finally got them on, never will I remove them again... Try to line up the middle clips first then work your way out.
