Procedure for removing the steering wheel
Old Feb 8, 2021 | 09:04 PM
Default Re: Procedure for removing the steering wheel
When they replaced my airbag during the recall, they only replaced the airbag itself. It is a separate assembly BEHIND the horn button assembly. It was a pretty small package, just the airbag. I should caution those who buy an airbag off Ebay, do you know if it came off a recall based car? The recalled Crossfires were the model years 2007 and 2008, all trims.
Old Feb 9, 2021 | 10:56 PM
green24u's Avatar
Good Point. Original airbag was from a 2005 Limited Roadster with the stamped code: YP1R5H3QBHL and a sticker: TKP-Nr16 1877.99.32 /BT3241960009. I'll have to compare the two airbags & do some research to see if the code can be deciphered.
PNA
Nov 12, 2020 04:44 PM
ala_xfire
Aug 16, 2015 09:45 PM
da pink
Aug 12, 2015 05:20 PM
princepenson
Jul 29, 2015 07:44 AM
Blackout317
Jul 7, 2015 08:38 PM
