Dim Speedo and Tach
Old Jan 4, 2013 | 09:05 AM
caddymike85's Avatar
Default Dim Speedo and Tach
Hi Everyone,
I recently encountered a small problem/nuisance in my 2004 Limited where the right side of the speedometer and the left side of the tach are dim compared to rest of the gauge cluster. The lights are not completely out but noticeably dim comparatively. The gauges work fine and all the other dash and gauge lights are fully on. I was thinking this would be an easy fuse replacement and that could still be the case but if the problem were a fuse then wouldn’t the lights on the entire gauge cluster be out? Anyone have any thoughts or run into this problem before? The last thing I want to do is take out the entire gauge cluster. Thanks.
Old Jan 4, 2013 | 01:49 PM
robby363's Avatar
Default Re: Dim Speedo and Tach
It sounds like you have a bulb out.
Old Jan 4, 2013 | 02:04 PM
robby363's Avatar
Here is a picture of the back of the housing. There is a bulb on each side of the speedometer and if one is out it would explain why half the speedo and half the tach are dim.
PNA
Aug 30, 2024 02:06 PM
PNA
Nov 12, 2020 04:44 PM
pioneer4x4
Sep 12, 2015 11:13 AM
Rickyms
Sep 13, 2006 11:02 AM
REDSC400
May 18, 2005 01:11 AM
