Base roadster interior light question
Old Apr 27, 2013 | 09:46 PM
xjken's Avatar
Default Base roadster interior light question
I notice that when I open the door to get in my roadster at night there are no interior lights. There is a light at the top of the windshield header and according to the manual if you slide it to the right it lights and it stays on, slide it to the left for auto. So mine is slide all the way left and the lights never come on. Also do these cars have any lights in the footwells because I can not find any?
Old Apr 27, 2013 | 11:39 PM
robby363's Avatar
Default Re: Base roadster interior light question
If you leave the switch in the center it should be on auto and should fade out after about eight seconds. left is off and all the way to the right they should stay on. there are no footwell lights.
Old Apr 28, 2013 | 11:09 AM
Does the trunk light work when the lid is opened ?
Does the remote lock and unlock the doors ?
If not, then check fuse #9 in the under hood fuse block.
( see https://www.crossfireforum.org/forum...sh-button.html )
Old Apr 28, 2013 | 11:23 AM
I wonder how you thought of this as a possible reason?
Some times the simplest reasons for a problem are the last to be looked at.
Old Apr 28, 2013 | 12:19 PM
I was frustrated from digging through the schematics and metering.
I walked out in the garage and opened the trunk for something and it hit me that the trunk light hadn't been working since the locking problem started.
I immediately checked the interior light, since I knew they were on a common circuit, and neither bulb ( LED ) worked there either.
I dug back into the schematics and saw that F9 not only fed the lights, but also provided B+ to the BCM. EUREKA !!!!
( I suspect that particular lead to the BCM is used to power the CAN bus to the locking pump module )
I replaced the fuse with same amperage, and it has not blown again, so I have no idea what took it out initially.
Old Apr 28, 2013 | 05:14 PM
xjken's Avatar
The switch on the windshield header has no middle option, all the way right turns it off and all the way left turns it on. As for the trunk area I do not see any light in there at all. I'm guessing that's just the way the base models came.
Old Apr 28, 2013 | 05:36 PM
robby363's Avatar
My bad, there is no middle position. I just went out and looked at mine and left is off and the right should be the auto mode.
Old Apr 28, 2013 | 07:57 PM
These things can be wrong but the Base and LTD specs say there is the same interior lighting specs.
Lamps
Cargo compartment __________________________________________________ _____ S S S S
Front courtesy/map __________________________________________________ _____ S S S S
Glove box __________________________________________________ _____________ S S S S
The first and third S is for the Base model.
Kodebuster
Nov 5, 2020 04:06 PM
stlas69
Sep 3, 2015 10:28 AM
Rusty475
Jul 13, 2015 10:03 AM
Blackout317
Jul 7, 2015 08:38 PM
Mackel
Jul 6, 2015 10:54 PM
