Power seats not working
Old Jul 2, 2016 | 07:57 PM
Raindem's Avatar
Default Power seats not working
The power seats on my 2005 limited coupe intermitently stop working, then start working again for no apparent reason. One day they work. The next they don't. The next they do again. This affect both seats at the same time. I've checked the fuses when they stop working but the fuses are good.
What else can I look at that would affect both seats at the same time?
Thanks
Curt
Old Jul 2, 2016 | 08:39 PM
Kingdav1954's Avatar
Default Re: Power seats not working
Thanks
Curt
Power seat relay.check the repair manual, you can find it here on the forum and download it . Or use the search function and type in power seat relay.😉
Old Jul 2, 2016 | 09:44 PM
Raindem's Avatar
Yes, I have the repair manual. Where is the relay located? It's not in the relay control module and the book doesn't say where it is at. Thanks.
Old Jul 2, 2016 | 11:00 PM
Thanks
Curt
You can read this PDF I did and see what your problem might be, also see where the relay is located on the firewall. CLICK
Old Jul 2, 2016 | 11:46 PM
Raindem's Avatar
Ah. I knew there was a PDF on here about this but I couldn't find it in my first search. Thanks, that was very helpful.
So if I understand this correctly, the sole purpose of this relay is to control operation of the seats depending on whether the doors are open or closed? I don't understand why they thought that was necesssary but that's a rant for another time.
I'm terrible at soldering so I'll probably just replace it. But what would be the harm of jumpering the connector so that there is always power to the seats? Would it run down the battery when the vehicle was parked?
Old Jul 3, 2016 | 11:01 AM
And risk making a wrong connection or shorting something out? If the relay is bad, just replace it. If it is a loose wire, replacing the relay will not help. The relay replacement may be the least expensive option (which I subscribe to, least expensive), but if it doesn't work you'll have to get the wiring diagram and hunt a loose connection (not a good thing to look forward too).
Old Jul 4, 2016 | 10:41 AM
If BOTH seats refuse to move, then BOTH work, then later BOTH refuse to move - it's the seat relay.
Old Jul 4, 2016 | 01:37 PM
Raindem's Avatar
Yep, I agree it's the relay. I don't look foward to replacing it. I always seem to break things when I try to take a dash apart for the first time.
Old Jul 4, 2016 | 02:00 PM
It's easy. You can use the "Sticky Key" tutorial (and while you are at it, you should DO the sticky key mod, as well).
If you don't go ahead and do the sticky key mod - you need only follow the first few steps of the process. I beleive all you need is a #2 phillips screwdriver.
JOE6C
May 26, 2016 06:16 PM
dsdesigns
35
Apr 21, 2016 09:55 AM
theglot
Apr 16, 2016 10:30 AM
IsaacF
Apr 12, 2016 03:14 PM
srbaker
Apr 7, 2016 04:56 PM
