Interior of Crossfire Falling Down
Old Sep 10, 2022 | 06:48 PM
Thunder1998's Avatar
Default Interior of Crossfire Falling Down
Hello I'm not native speaker of english so I don't understand something, please reply this thread.
Yesterday when I was to opening the hood and the interior of the car fall down, not completly but fall.
Attach video:
https://drive.google.com/file/d/1pKe...ew?usp=sharing
What I can do to fix this? Should I to talk with and specialist? What are the specialists called?
Anything would help, it's appreciated.
Thank you for read!
Old Sep 11, 2022 | 09:32 AM
JoeO's Avatar
Default Re: Interior of Crossfire Falling Down
It appears someone took that panel off to repair something.........and did not replace the screws when they put the panel back.
In the video, it shows a part of the panel that has a hole. This is where one of the screws should have been.
someone in this Forum would know the size screw(s) you should buy
Old Sep 11, 2022 | 12:36 PM
As told by member JoeO, you have a loose lower dash panel. When you pulled on the hood release, the panel separated. It seems the prior owner(s) had someone take apart the dash (for whatever reason) and this person did not put all the screws back in that he or she took out. To fix the current issue, acquire a few screws that will fit in these locations (easily seen, in the lower dash locations where a screw looks like it goes), and tighten them up to their original location. The larger picture, is WHY was the lower dash panel removed in the first place and are there more loose things inside? Good luck!
Old Sep 11, 2022 | 02:52 PM
If you look in the ‘Sticky Key’ CLICK mod you will find a description of the cover screw locations.
Also your fuse cover is on crooked.
Old Sep 13, 2022 | 11:13 PM
Hi everyone.
Thank You for you quick replies!
As said @JoeO and @GraphiteGhost the screws are loose. I don't have the tool to tight the screws but actually located which are loose.
Yes, two years ago the panel was removed to install a GPS but then stopped working and I never removed.
Another question, whick GPS do you recommend to install to the Crossfire?
@onehundred80 thank you! That document help me a lot to find the screws. The fuse cover I have to replace the screw or what can I do to repair?
Thank you to all!
You helped me a lot!
Old Sep 14, 2022 | 11:59 AM
Originally Posted by Thunder1998
Hi everyone.
Thank you to all!
I own a windshield suction-cup mounted GPS, old school but it works perfectly and not a distraction as I mount it at the very top of the windshield ahead of me. Whatever you choose (hidden or not) the choices are varied and ultimately up to you. Hope your able to find the screws and 'tighten her up'. Good luck!
Old Sep 14, 2022 | 10:52 PM
Thank you for the recommendation and the luck!
Old Sep 15, 2022 | 08:05 AM
Lboudreau's Avatar
got my material for top at Joan,s fabric 20$ and can of spray tack at home depot. acetone to remove the old glue.
texas t
Dec 20, 2008 09:17 AM
MAKIII
Aug 7, 2008 09:43 AM
noles
Jul 9, 2008 03:07 PM
kornonthekaub
Aug 24, 2005 02:49 AM
JetCity
Aug 24, 2004 11:04 AM
