Raise driver seat
Old Feb 5, 2025 | 12:06 PM
benherr1's Avatar
Default Raise driver seat
I am short and need to raise the seat several inches
Old Feb 5, 2025 | 04:18 PM
dcskmail's Avatar
Default Re: Raise driver seat
If you've already raised it to the maximum height, the simplest thing would be a cushion other than putting spacers and longer bolts which may not be the safest thing in a accident
Old Feb 5, 2025 | 05:54 PM
Nelson G's Avatar
Look on Facebook I saw some advertising a metal block that will raise the seat. If I see the ad again I will post the info for you.
Old Feb 11, 2025 | 10:02 PM
Fastenyourseatbelt's Avatar
Raising the seat would be easy if the rail bolts were parallel, but they are not. The forward rail bolt is angled which requires the seat to move forward as it moves upward.
A longer bolt and a metal spacer for the forward reattachment is straightforward. However, now the longer bolt at the rear will not line up with the threaded hole on the floor.
It is possible to fabricate a metal contrivance that will accommodate this problem...I did but I prefer not to share the design due to liability.
Good luck....you will figure it out.
Old Feb 13, 2025 | 03:13 AM
Base model? (Cloth seats, no fog lights). If so there is a lever on the left side of the driver's seat (North America). Use that lever like a pump to raise the seat.
Limited models have power seat adjusters. If they are not working, then most likely the relay is bad or a fuse has blown out.
pim
Aug 11, 2024 02:27 AM
K3522
Jun 25, 2024 10:47 AM
colink
Jul 19, 2018 10:15 PM
ASQRD
Aug 17, 2011 05:36 PM
L5-S1-SVT
Nov 11, 2007 05:14 PM
