Fluid leaking from rocker panel
We have a 2007 coupe and have been very happy with it. We recently started to notice a thin clear fluid on both sides of the car dripping on to the garage floor. This is mostly within about 16" behind the front wheel well and seems to be dripping from the rocker panels. No rust is evident. All the fluid levels - brake, oil, power steering, coolant and transmission seem to be stable and full. The fluid crystallized on the garage floor, is odorless and does not seem irritating to the skin. This has been happening in the summer in dry weather. The volume is not large ( maybe an ounce or two) but is persistent. The car has been washed several times since any contact with Michigan road salt (and we rarely drive it between November and April). The fluid was persistent even a week or more parked in the garage while we were on vacation over the summer. Any suggestions or similar experience?
Re: Fluid leaking from rocker panel
Originally Posted by Leslie
(Post 759388)
If the drains are plugged it is possible for the water trapped behind the plug in the drain to slowly seep past the plug and drain over the course of a few days or so. Would that be possible in your case and have some relationship to the car being washed? The crystallization could just be salts in the concrete floor being pulled out. The drains get plugged with leaves and debris and as they get plugged they filter smaller and smaller particles ending up plugged entirely. This is a problem on this car and others, the drains should be inspected more often when the car is parked under or close to trees with small leaves especially. Leaves that pass through the drain collect behind the fender, I know as I have cleaned them out. |
Well, check your windshield washer fluid. The tank is on the passenger side, in the front wheel well behind the inner liner and may be the culprit.
Les |
Thanks! Will check out drains:)
Originally Posted by velociabstract
(Post 759462)
Les |
(Post 759463)
I park my car in the garage, and it is seldom left on the driveway near the trees with small leaves. So anyone who has not looked at their drain lately should or a deluge could enter your car and possibly ruin the amp etc or at least make the carpets wet. |
