New 2007 crossfire roadster owner
Hello crossfire owners I purchased a 2007 red crossfire roadster with 13000 miles 3 wks ago. I am located in warren, oh area. I purchased this car from a Chrysler dealer unfortunately they have had for 2wks fixing a top problem. They have have sent the car out to a top shop to replace a sensor which was done but they need to now calibrate it which has now taken a couple of days. I have been reading all of the post on this site concerning top issues and have not found any info on calibrating? Am I being misinformed?
Any thoughts or suggestions would be appreciated. Thanks |
Re: New 2007 crossfire roadster owner
Re-post this under the roadster category and describe the symptoms, windows go down, top unlatches but does not move, switch beeps, trunk divider is in place etc. for more feedback. Also search and read the many postings on top issues. I would be very afraid of a dealer but if it is under warrantee ???
The dealer did give me a 90 day warranty thats why I took it back . If I they fail to fix the problem I will post symptoms. What is the proper sequence of events when lowering the the top?
There is NO calibration involving the top.
Sequence : When it's working ( putting top down ) : 1. unlatch the "D" handle and slightly raise top, windows will go down. 2. press and hold the rear of the top switch. 3. You will hear the bow lock release, then the rear bow will raise. 4. You will hear the tonneau latch release, then the tonneau cover will raise. 6. The top will retract into the well. 7. the tonneau will close and latch. 8. You will hear one beep indicating successfull operation. putting top up " 1. press and hold the front of the top swirch 2. the tonneau cover will raise 3. the top will raise 4. the tonneau will close and lock. 5. the rear bow will close and lock 6. you must pull the top carefully closed with the turned "D" handle, then latch. 7. optionally, you can press the top switch twice rapidly twice in the up direction and both windows will raise. Manual process : see pizzaguys video : https://www.crossfireforum.org/forum...operation.html |
"Calibrate it" - yea, that's a phrase uttered by someone who knows nothing, NOTHING of what they are talking about.
Our world is going to hell. Here we are, in a world filled with electronics and electro-mechanical devices, systems and product. Yet, no one is learning or teaching electronics/electronic troubleshooting as a vocation anymore. If I did not have a 34 year background as an electronics technician, I'd have never bought my second, let alone third, Crossfire Roadster. |
Originally Posted by yamjski
(Post 893710)
Any thoughts or suggestions would be appreciated. Thanks Oh, and it's common practice for dealers to send their convertible top work to an outside upholstery shop. They can't afford to keep that kind of skill around when it's not required that much. And as such, upholstery shops will have varying skillsets when it comes to working on tops. |
(Post 893710)
Another option I know will work "just for the convertible top module" on 2007 and 2008's is Witech software on a laptop, a starmoble device in passthrough mode, and the same special Crossfire cable.
How does one acquire the Witech software is this something the dealer might know about? I was told by the service manager that they are trying to borrow a scanner from another dealer in the Cleveland area because theirs wont save codes? sounds fishy to me?
The main issue was the rear bow would not securely latch the top down completely . I do want to Thank all of you who have responded, I feel blessed to have found this site Thank You |
(Post 893857)
(Post 893857)
The main issue was the rear bow would not securely latch the top down completely . I do want to Thank all of you who have responded, I feel blessed to have found this site Thank You The Starmobile device was replaced by what they called VCI pods, and then micropods. I don't know if those devices with the Witech software work with a Crossfire. |
Originally Posted by Kingdav1954
(Post 893859)
I remember reading a previous thread about the rear bow latch adjustment, if I'm not mistaken it is in the crossfire service manual available here on the Forum for download, might be worth your time to take a look the solution to your problem may be as simple as adjusting that latch.
What is the difference between a roadster and other crossfire's
1. The convertible top and associated pump and wiring, of course.
2. the switch on the console ( and a locking console lid ). 3. extra body stiffener bars. 4. the tonneau cover and trunk lid. 5. the spoiler 6. the rollover bars 7. a rear window that tends to fall out after about 8 years 8. the wind in your hair |
Originally Posted by RICKFRINK
(Post 894417)
(Post 894419)
Then I must have a roadster I have a convertible
