Abs ebs and all brake lights come on
Old Jun 29, 2015 | 08:32 PM
Retrostringbean's Avatar
Default Abs ebs and all brake lights come on
My crossfire won't start and it was running just fine yesterday and then abs, ebs ,e-brake and brake wear sensor came on. It wouldn't shift and the spoiler came up help me please
Old Jun 29, 2015 | 09:04 PM
RL67037's Avatar
Default Re: Abs ebs and all brake lights come on
How many miles are on the car?
How old is the battery?
Have you ever done any service on the car?
When you say "won't start", will it turn over or is it completely dead?
Do you have CEL?
Old Jun 29, 2015 | 11:03 PM
New battery. I have done service on it regularly. When I try to start it it just makes a click and I don't know what CEL is lol
Old Jun 30, 2015 | 08:08 AM
RL67037's Avatar
Hahaha ... CEL = Check Engine Light
If it just "clicks" when you try to start, have you unhooked the battery for about 30 minutes then re-hooked it and try again? Sometimes these cars will get a voltage anomaly that will cause their brain to hiccup.
Typically, when the spoiler pops up for no reason, that is an indication of low voltage (normally from a bad battery).
It is also possible that the starter has died, but I would try other things before pulling that out.
As far as it not shifting, if you have over 75K on the car and if you have never had the fluid changed, it might be time to do that.
RL
Old Jun 30, 2015 | 09:52 AM
See it is fine until all the brake sensors go then it won't shift and if I try to put it in anything other than drive it acts like it's in neutral
PNA
Aug 30, 2024 02:06 PM
PNA
Nov 12, 2020 04:44 PM
xfClifford
27
Nov 10, 2015 10:08 PM
PNA
Jul 27, 2015 12:28 PM
Blackout317
Jul 7, 2015 08:38 PM
