FS - SRT Springs
Old Apr 13, 2010 | 08:04 PM
bmorgan's Avatar
Default FS - SRT Springs
SOLD!!!!
I am selling my stock SRT springs. I bought a set from a forum member last year to cut to lower my car. I kept the originals in case I did not like the results. Well, time has proven that the cut SRT springs are to my liking, so time to let my originals go. These are non progressive springs, so cutting them is not a concern. Many forum members have done this and swear by them, as I do. So whether you have an NA that you just want a more aggressive ride, or you want a great alternative to the progressive lowering springs. This is it. Asking $125 with free shipping in the lower 48. Thanks Bob
Old Apr 14, 2010 | 01:00 AM
240M3SRT's Avatar
Default Re: FS - SRT Springs
I second this. I just cut my srt6 springs and love em'.
Great price!
Old Apr 14, 2010 | 08:48 AM
bmorgan's Avatar
This thread is from a member who put SRT springs on a Limited.
Installed SRT-6 spring on Limited
Old Apr 14, 2010 | 09:24 AM
hcarter's Avatar
Bob you cut your springs and did the Koni shocks is this correct ,,,,?
Old Apr 14, 2010 | 10:48 AM
bmorgan's Avatar
No Howard, I stayed with the stock shocks. For my purposes, I have not seen a need to change the shocks.
Old Apr 15, 2010 | 08:46 AM
bmorgan's Avatar
Bump.................
Old Apr 16, 2010 | 12:38 AM
MikeBrink28's Avatar
How hard is the removal, cutting, and reinstalling?
Old Apr 16, 2010 | 12:52 AM
bmorgan's Avatar
The back ones are pretty easy. The fronts are a bit of a pain. The main pain with the fronts is getting the "A" arm to line back up to get the bolt in. I have not worked on a car since my teens until I got the crossfire, and I was able to do it with no problem. To cut the springs, you will need an angle grinder with a cutting wheel. If you do not have one, I could cut them for you. Attached are the instructions that I used to install mine.
EDIT: Others have said the fronts are much easier if you have a spring compressor, which I did not have. You can get one from Harbor Freight for about $13. A spring compressor is definitely not required to do this though.
Here is a link to an easy to follow tutorial https://www.crossfireforum.org/forum...5-srt-6-a.html. The pdf attachment is a combination of two posts.
File Type: pdf
Old Apr 16, 2010 | 10:11 PM
32krazy!'s Avatar
the common spring compressor wont work bob. you need a european setup which i have and its such a pain in the a** to use i tossed it on the floor and did it the old fashioned way!!
Old Apr 17, 2010 | 06:31 PM
bmorgan's Avatar
Old Apr 17, 2010 | 06:59 PM
velociabstract's Avatar
I don't know if I need them yet! I have to get the cut ones in to see if I want to go back to stock or not. I'll let you know, hopefully sooner than later.
Les
Old Apr 19, 2010 | 07:47 PM
bmorgan's Avatar
These are still available.
Old Apr 20, 2010 | 12:18 AM
bmorgan's Avatar
The springs have been sold. Thanks everyone
PNA
Nov 12, 2020 04:44 PM
tom2112
Dec 1, 2015 09:02 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
UNDER PSI
Jul 18, 2015 02:12 PM
turboomni08
Jul 7, 2015 11:48 AM
