13 sec. "STOCK" N.A. XF by the book
Originally Posted by ashonfire
Assuming that you mean an "extra" 130 hp, then why do you say that you need 345 hp to turn a 13.9 sec. E.T. with a 3.27 gear, when a stock SRT runs 13.3 sec. with 330 hp and a 3.07 gear? Just curious.
Guest
Posts: n/a
Just from experience running a base coupe with lighter wheels and tires, being a great driver, and modded out the ***, I'm gonna say NO. What works on paper doesn't work in reality. The TC is s ointrusive even with it off that it makes launching impossible.
I think you would be much better off with an auto to get this done. The more HP you have, the worse the manual performs.
But I applaud you for keeping the faith high.
Actually, the ESP has more to do with the direction the car is traveling vs the direction the steering wheel is pointing.
I don't see how TC would do much of anything in a straight line. There's also something wrong with your tires if you're getting interference from TC on a quarter mile drag race!!
The ESP, and ABS are so tied together, the brakes may be applied automatically with wheel spin
So, what pressure do I run on my tires?
Nitto Invo. I'm taking my wheel spacers out and going back out there asap. I usually put 36 in the front and 35 in the back.
Nitto Invo. I'm taking my wheel spacers out and going back out there asap. I usually put 36 in the front and 35 in the back.But as long as you don't engage your "juice" until your car actually starts moving, the fact that your car is an automatic just might be a great reason to try some "lighter" 16" SLK wheels. Especially with a tire at least an inch shorter than stock hight. That would make your car perform more like it had a 3.46 gear.
On the downside, my anti-locks are deactivated as well, but my car never see's winter, and I've only been caught in the rain about 1/2 dozen times with it.
With the TC off, I can modulate just a little wheelspin that goes away quickly and sends the car down the track.
With the TC on, whenever my wheels start to spin, the system engages and modulates the brakes as well as pulling spark and fuel. This creates a bigger delay than just a little wheelspin does, as the car needs to recover before everything is back to normal and it allows you to use full power again.
It's a short delay, but when you're talking tenths.......
Originally Posted by +fireamx
Going by Apkano's post, he might disagree, as do I.
I wish I had more power! That way I could possibly get a good strong launch by starting in second. First gear is so short, no sooner do you start rolling and it seems that you run out of gear. By eliminating one shift in the quarter mile my times would be MUCH better.
I do get pretty abusive at the track, and I do use the "no-lift-shift" procedure, but still, when you're talking tenths....
Originally Posted by apkano
You're right, I completely disagree.
beating the syncros and all. But at the drags, that's definitely what's necessary to get the best times for sure.As much as I would like to have a lower gear ratio available for our cars, say 3.55 or even 3.73's, it would totally render our 1st. gear (in the 6spds.) useless. But boy would it wake up the automatics.
For some reason, mine shifts great when using the "powershift" technique. I find that it's a sticky 1-2 shift when driving normally around town.
As far as a lower gear, I'd love it. I usually have to shift to 4th about 75 feet before the finish line....it would be great to be able to just hold third through the lights.
You must have read my mind, because I was going to ask you if you needed to use 4th. gear in the 1/4.
You're right, that extra shift does cost precious time. Every magazine road test I've read about the Viper GTS says it's supposed to run a 12.2 sec. 1/4 mile. But in the Viper magazine, some guy broke into the 11's simply by not shifting into 4th. I'm gonna assume he was beyond redline going thru the traps, but with no rev limiter it's possible to do in the Viper.
How's this sound? Install a SRT's 3.07, launch as hard as you want, stay in 1st. gear longer (thanks to the 3.07) and go thru the traps in 3rd.
Steve it seems I've read that same comment here on the forum before, that driving more aggressivly makes the manual operate better. To be honest, I never noticed. Maybe I should pay more attention huh?
Last time I was at the track, NeedsWings offered to let me try his drag slicks. Wonder what he'd say if I asked to try his whole rear axle?
LOL....I like it!
You need to be very careful when asking to use ones rear end
I have played the 1/4 mile numbers games till I was blue in the face. I play with numbers all day, so it's a natural desire. And you want to cross the line as close to your 'redline' or power peak as possible.
Agreed that lowering the FD would help this, but you need to make sure you have good midrange torque to pull it.
A lot of what you guys are talking about is what has me really wanting to find a base coupe. Less weight to start and less to worry about going wrong.
