Racing The place to talk about autocrossing, road and drag racing.
3 laps at Salinas Speedway
Old Mar 12, 2012 | 09:52 PM
velociabstract's Avatar
Default 3 laps at Salinas Speedway
It was hot on Sunday in Salinas. 92º to be exact. So here's my video of 3 laps of which 2 are my fastest of the day ..... that I know of. I didn't bother to stick around to pick up my times for the 3rd heat.I had several in the 108's which makes me happy. It means I'm getting more consistent. I hope it's enjoyed by all.
Salinas Speedway March 11, 2012 - YouTube
Les
Old Mar 12, 2012 | 10:15 PM
ZAHANMA's Avatar
Default Re: 3 laps at Salinas Speedway
Great vid as always Les.
I do have a question for you? Were you able to get the links installed in the rear end already? If so, did you notice any improvement in your handling by taking the pre-load off of the sway bar?
Old Mar 13, 2012 | 06:40 AM
The links are in. First impressions are that the rear suspension handles the bumps much better in the curves. Breakaway is more predictable and it's easier to bring the back of the car in line. If you watch closely you will see the rear start to slip a couple of times. Adjusting the throttle imput brought it back immediately. After the first heat I lowered the rear pressures and the back of the car was gripping better. Taking the tension off the bar allowed the rear half of the car to lean a little more than normal. In recent track photos the front is leaning more than the rear and now I believe the lean is even. I'm deciding which direction to go next. Adjust my rear alignment or slightly tighten up the bar. As with any new adjustment, I have a learning curve to go through. The way the car feels is a night and day difference and my times improved. These links may even help drag racers. Loosen the bar all the way and you should get a little more weight transfer to the rear. Not a whole lot, but perhaps enough to make a difference.
So to sum up. These links will improve your ride IF your car is lowered and you take the preload off the bar. The rear of the car will behave better in the corners, more compliant. As far as speed in the corners, that comes with confidence. So far I discovered that the chance of something bad happening I can't control is less likely. I keep getting faster so I'm a happy camper.
Les
Les
xjken
Sep 6, 2015 11:37 AM
The Toy
Southeast Forum
255
Sep 11, 2008 08:12 PM
The Toy
Southeast Forum
81
Oct 10, 2007 04:20 PM
The Toy
Nov 3, 2006 09:12 AM
The Toy
Southeast Forum
94
Oct 17, 2006 10:17 AM
