OBDII scanner recommendations
Re: OBDII scanner recommendations
Seem to be a number of different ones by iCarsoft. do you mean this one ?
Then you just tell the scanner it is a SLK320 and it will reset the SRS (air bag) light in a '07 Crossfire ? If so will just order one.
Hate to beat this to death (but have been called AR, OCD, and HFA) but have you ever used it to reset the SRS system (air bag) on a '07 or '08 Crossfire ? Apparently something is different hence the STAR bulletin.
Have you ever just checked yours with the iCarsoft to see if it can talk to it ?
My concern is that the dealer that did the airbag recall on mine at first said it was the URC (SRS system controller) because their system could not talk to the SRS system at all. So if the iCarSoft system is able to verify that your '07 is working properly then I would feel a lot more confident about buying one.
OK, just ordered my Christmas present to myself. Have been looking for something that could handle both my '07 Crossfire and '01 SLK320 ('01 was first year of 16 pin OBD-II connector). Have been waffling for some time since found that Carley Pro for Mercedes only works with later cars and you convinced me to try the iCarsoft. Should be here next week.
Still like Torque pro for quick looks via Bluetooth (have a dongle in each late car) but this should handle the Mercedes based.
Will the iCarSoft MBII has arrived and is apparently not the same as the i980. Works for full diagnosis on both the '01 SLK320 and '07 Crossfire. Does list the SLK32 AMG so expect you also work on SRT. Is able to talk to the SRS system on both.
Still have some things to learn but is the most useful for under $200 I've seen.
It has a "generic" OBD-II capability, essentially the same as Torque Pro. Difference is that the MBII also reads all of the proprietary subsystems in a Merc (and the same ones are used in the Crossfire - is really very little Chrysler except the badges, wheels, and rear wing.
ANFSCD - Record Mode.
In my MBII I have under TOOLS these is a setting "Record Mode". This is not covered in the manual. Hopefully this allows saving of test information ("REC" is on the screen during testing) to an offline device. Any idea how do I do this or otherwise use this setting please ?
Under REVIEW is an Upload Record setting but says it is not supported in this version.
Sorry, I haven't had a need to record any data. Their website question form is here: www.icarsoft.us_Questions
Well this is a crock. For Mercs in general I keep a record of test runs so I can compare if anything changes. Torque Pro and Carley Pro bot provide a way to send or upload the logs and test reports. If the iCarSoft MBII is unable to save or upload reports that is a major problem.
I have this one and I know many others here who do as well
This is how I found out about mine and bought it
UltraGauge OBDII Scan tool
Bill T.
