Let's discuss the key fob transponder chip(s)
Re: Let's discuss the key fob transponder chip(s)
I don't think that it is possible to clone the keys. But it is possible to make keys with a dump of the skreem modul.
Unfortunately I don't have the necessary hardware to prove it. A original Tango programmer with Crossfire module costs 1400$ and the clone should not work with Crossfire.
But I managed to repair a defective skreem module. Here is a video where you can see the repaired module in my car (unfortunately in german) password is "xf" (without quotes).
But I managed to repair a defective skreem module. Here is a video where you can see the repaired module in my car (unfortunately in german) password is "xf" (without quotes). video
Also, some auto locksmiths seem to have hardware that can produce working keys based off of a dump from the SKREEM module. See here.
The defective Skreem module was no longer recognized if you wanted to read it via obd.
So I had to desolder the processor. Then I read out the processor with my Orange5 programmer. This was fortunately intact and all data were present.
First I tried to clone the processor to another one.
Unfortunately the clone did not work completely. I could open and close the car with the key but I couldn't start it. I have to look a little deeper into this.
The processor has three areas where data is stored and I only cloned one. And it could also be that the processor was from an SLK R170.
Finally I soldered the original processor to another Skreem module, that worked fine.
Unfortunately I don't have the right hardware (Skreem, ECU and key from one Crossfire) at the moment to start more attempts.
In which case the replacement if a ten cent item may solve the problem.
Which programmer do you mean? If you mean the Tango programmer, he can use his software to calculate the code for the transponders of the unused keys from a skreem dump and write it to an empty transponder.
The codes for 8 keys are stored in the Skreem module, but normally only keys 1 and 2 are used.
I only have one key. I just ordered a new blank chip and wondered if the new chip can be programmed by the dealers' computer. Another forum member wrote about a tool that can be purchased on Ebay that has the software for programming the chip.
I don't think the dealer knows how to program a transponder for a Crossfire because it works differently than other Chrysler models.
Chrysler can use the VIN to provide codes for the transponder. However, they only do this to locksmiths and dealers.
And a software that can program the transponder is useless without the data that belongs on it.
And as far as I know the only way to get these codes without Chrysler is to dump a Skreem and the right software.
edmoncwheeler - So, does that mean that China will be making SKREEM modules and remote key's for our Crossfires? If someone made them for a reasonable price, I venture to say that better than 50% of the guy's on this forum would be buying them. Since you indicate that you are an importer of China and Taiwan goods, do you know anything about them copying our SKREEM module's or keys?
Jim
Jim
I called these people they said they helped you but were not willing to help anyone else. I was so disgusted and furious they pick and choose who they wish to help. The key company said it was hard to get keys and cost to much to reproduce . I think we are all screwed when it comes to these dam keys 😡😡😡
😞 Since I cannot get another key for this dam car if I decide to extract the transponder out of my one good key do I glue or tape it to the inside of Antenna ring i would feel uncomfortable glueing it to antenna ring if I had to remove it. Seems it would look better glued to the outside antenna to keep from breaking it off when I turn key. Can I glue it to outside behind rubber ring ??
I had thought same thing Chooch to Buy another antenna ring and glue the transponder to the good antenna and hide it behind the dash somewhere and use a bad antenna as a cover over the ignition key hole. does anyone have a bad antenna willing to sell cheap ?? I have paypal . The thing that scares me to death now , is busting my one good key open YIKES !!!
Thanks to all of you who have contributed to this thread and everything I have learned has been a great help to me and to those of us fairly new to this car. I have learned so much from all of you and I am eternally grateful !!!
Thank you Thank you
so you did call them and they did tell you they helped me and the price was $85 per key? Infact i bought 3. Only thing i hope is that those of you that thought i was a troll and thought i was trolling are regretting ever thinking or saying this, i could have been a sweet deal for all of us.
