Which Mercedes?
Old Apr 1, 2006 | 01:44 PM
04Roadster's Avatar
Default Which Mercedes?
Which Mercedes motor do we have? I have seen SLK 320. I'm guessing that SLK is the body style and 320 is the type of motor, but I'm not sure. I'm far from a Mercedes expert, but there is a Mercedes plant in Tuscaloosa Alabama, and I have a friend there who I need to ask some questions, and don't want to look stupid with some basic questions... So I'll just look stupid in this thread. I will post all any good info I can find from him.
Old Apr 1, 2006 | 03:03 PM
xfire1's Avatar
Default Re: Which Mercedes?
we have the 320 that is in the slk... and something like 80% of car... is MB... something like that!
Old Apr 1, 2006 | 03:28 PM
HDDP's Avatar
It is the Mercedes 112 engine ?
Old Apr 1, 2006 | 06:43 PM
Cobra953's Avatar
From the factory sticker:
Parts Content Information
Major Sources of Foreign Parts Content:
Germany: 80%
For Vehicles in this carline:
U.S./Canadian parts content: 1%
Ok, that accounts for 81%...they forgot to tell us where the other 19% came from...I wonder why? Sounds like a conspiracy to me...
Old Apr 1, 2006 | 06:59 PM
HDDP's Avatar
The remaining parts are from Mars, that's why nobody can figure out how to build performance products for the car.
Old Apr 1, 2006 | 07:25 PM
cgates's Avatar
Germany: 80%
I believe the rims are from Poland.
Old Apr 2, 2006 | 01:13 AM
stryfox's Avatar
Too true.
lol
Old Apr 3, 2006 | 01:23 AM
feets's Avatar
It is the Mercedes W112 engine ?
Close, real close. The W112 was a car built in the late 50's if I recall correctly.
The W signifies sedan such as a W210 ('96 to '02 E-class).
It's a 112 motor. I believe it's a 112.981 variant or later. The 112.961 and earlier motors had a different ignition system (and a few other things).
MB Likes numbers. Those friggin German engineers must engineer everything! It's almost like they're obsessive/compulsive or something.
Mercedes issues engine, transmission, and chassis numbers that look like an old VIN.
112.198.12.058736
112 = type of motor (3.2 liter V6)
981 = engineering variant
12 = automatic tranny (10 for standard)
058736 = sequence number to identify this engine (but I just threw 6 digits at random)
722.6xx.xx.xxxxxx for the transmissions in these ( 5 speed auto)
170.449.12.165540 Chassis number for a 2003 SLK230 Kompressor
170 = SLK model
449 = 2002 or newer 230 Kompressor variant
165540 = production sequence number
WDBKK49J47A165540 VIN number for above SLK
WDB = World Daimler Benz (most cars except ML, R, G, CLS, and SLR)
KK = SLK model
J = drivetrain layout (if I remember correctly)
4 = check digit
7 = code for year produced
A = Sindelfingen production plant (which is obviously wrong for the SLK but I don't remember what the digit is for Karmann)
Old Apr 17, 2006 | 03:43 PM
cgt_n_the's Avatar
So SLK320 for engine & trans. How about suspension parts? I have been told SLK32 parts will fit. I want to upgrade some items.
Old Apr 17, 2006 | 04:08 PM
HDDP's Avatar
Originally Posted by cgt_n_the
So SLK320 for engine & trans. How about suspension parts? I have been told SLk32 parts will fit. I want to upgrade some items.
The only suspension parts that would be an advantage to swap from the SLK32 would be the sway bars. The springs and dampers are swappable, but you should look at better after market parts. Eibach, K&W, Koni if you want to get the most bang for your buck. Also get thinner perch pads for the springs.
Old Apr 18, 2006 | 12:11 PM
cgt_n_the's Avatar
Thanks. Are those aftermarket Sway bars or Mercedes OEM parts?
Old Apr 18, 2006 | 10:33 PM
HDDP's Avatar
Mercedes OEM for the SLK32. More preload, solid vs hollow and 2mm larger in diameter.
Old Apr 19, 2006 | 10:16 PM
cgt_n_the's Avatar
Thanks. So you have the size of the stock ones handy? I searched for it for it was posted a while ago but missed putting my finger on them.
Old Apr 19, 2006 | 11:29 PM
HDDP's Avatar
I posted somewhere. Try searching srt6 limited specs. Or do a search on the posts I've made... It was probably 9 months ago.
miscetera
Oct 5, 2015 11:40 AM
4drturbo
Oct 2, 2015 12:58 PM
Billy22Bob
Oct 1, 2015 05:34 AM
Billy22Bob
Sep 26, 2015 10:16 PM
Sep 25, 2015 07:46 AM
