Originally Posted by cgt_n_the
So SLK320 for engine & trans. How about suspension parts? I have been told SLk32 parts will fit. I want to upgrade some items.
The only suspension parts that would be an advantage to swap from the SLK32 would be the sway bars. The springs and dampers are swappable, but you should look at better after market parts. Eibach, K&W, Koni if you want to get the most bang for your buck. Also get thinner perch pads for the springs.
