Fuel filler attached cable
Old Dec 11, 2006 | 09:50 AM
Kit and Kat's Avatar
Default Fuel filler attached cable
We had an odd and quite annoying incident this weekend, went to fill up the Ltd Crossfire and the cable came apart in my hands - the lid then wouldn't close, until I managed to touch the wires together... then the locking mechanism worked.
Have no idea how the wire broke... or why?
Old Dec 11, 2006 | 10:28 AM
woody's Avatar
Default Re: Fuel filler attached cable
Which cable? I am not aware of any exposed cabling near the filler.
Old Dec 11, 2006 | 04:45 PM
This was a wire inside the plastic link between filler cap and the hinge... it just failed.
Old Dec 11, 2006 | 05:20 PM
former NXMX5's Avatar
that's interesting... sounds like a ground loop, so the car knows the cap is on -- also sounds like you'll have to reconnect that wire. was it sheared off by the fuel door, or get caught in something and tear?
Old Dec 11, 2006 | 05:25 PM
It does need to be reconnected, not sure how, I spoke with the garage this morning as it clearly is both a safety issue and a challenge.
It appears to have just separated... the fuel cap is after all locked when the car's ignition is turned on. - it took quite an effort to get the car to reset itself.
I think it was metal fatigue that caused the wire to break, brought on by the very cold temperatures here last week, which probably made the plastic coating brittle.
Old Dec 11, 2006 | 09:57 PM
intenseblu's Avatar
i think he means the plastic string that attaches the fuel cap to the car so it does not get lost...
Old Dec 11, 2006 | 09:59 PM
Hi,
Yes I do but its not plastic it has a cable in the middle, and it is how the system locks the fuel cap.
Old Dec 12, 2006 | 09:58 AM
woody's Avatar
Hi,
Hmmm...this seems very strange. There is no reference to a ground or other connection in the wiring diagrams and the actual locking actuator is pneumatic not electric anyway. On mine the lock works irrespective of whether the flap is open/closed or if the cap is on or off. There is also no reference to a connection on the flap in the removal instructions. The wire might be there to discharge static to prevent a spark when the cap is replaced. Perhaps the US versions are different to the UK. Have yo got a picture?
Old Dec 12, 2006 | 11:05 AM
I'll take a picture for you today... the wire seems to prevent the filler closing, I solved the problem by touching the two bare ends, this enabled me to shut the filler door.
I'll find out more when I take it back to the dealer today...
Old Dec 12, 2006 | 06:37 PM
Just back from the Garage, and it appears that the problem was a build up of static... for some reason this prevented the lid from locking...
The linkage got so cold it went brittle... and broke...I thought there was metal inside it was that hard, but it turns out it was just very cold... 10f here one night.
Old Feb 16, 2010 | 09:16 PM
kszoz's Avatar
Help! Got my car back from the bodyshop today & the fuel cap cable/plastic string is detached from the plastic post. Almost dropped the cap on the ground. I think they busted it at the bodyshop when they took the quarter panel off. Would someone take a look ath theirs & let me know how it's kept on? It looks like something got snapped off the top of the post. And it looks like it's supposed to be one piece, but I'm not sure. Maybe I can glue something on top of it to keep it from coming off easily... Any ideas?
Thanks in advance!
Old Feb 17, 2010 | 05:23 AM
I find it hard to believe that static had anything to do with the problem. Static means sparks and sparks on gas caps mean a big bang. KAPOW
Valk
Jun 22, 2025 09:15 PM
roar
Jun 15, 2022 11:46 AM
Valk
Jul 12, 2021 09:49 PM
ozkancab
Sep 25, 2015 10:55 AM
Geechee1962
Sep 16, 2015 05:33 AM
