Rattle In Glove Box?
Old Jan 20, 2007 | 05:26 PM
acrispy1's Avatar
Default Rattle In Glove Box?
I have a rattle coming from my glove box not all the time. There is nothing in my glove box that would make the sound. It does sound like it's coming from behind the glove box. Any ideas?
Old Jan 20, 2007 | 06:30 PM
marauderroy's Avatar
Default Re: Rattle In Glove Box?
The cabin air filter is there, Maybe something got in. I check that first.
Old Jan 20, 2007 | 08:38 PM
jonnyangel04's Avatar
Is it a rattle or a fast clicking noise? Only thing I can compare it to is it sounds like a mouse running around? If its the noise I have it too its some valve that is opening and closing quickly there have been previous post of this same problem. It's not that big a deal to fix.
Old Jan 22, 2007 | 09:37 AM
spensley's Avatar
I had a rattle in mine once.
I cured it by removing my 9mm.
Old Feb 19, 2007 | 10:34 PM
CBXFIRE's Avatar
Does this happen when the AC is on? I sometimes get a rattle or slight vibration sound when the AC is on certain settings? Have you found a solution yet?
Old Feb 20, 2007 | 02:52 AM
its called an HVAC fan or recirc valve. i think what it does is recirculate the cabin air if i turn on my blower or the heat right away the sound goes away.
Old Feb 20, 2007 | 04:40 PM
acrispy1's Avatar
Thanks i'm going to try it next time i hear the noise.
Old Feb 20, 2007 | 11:11 PM
mooshim's Avatar
If this rattle is connected to something around 4 foot long with scales be careful removing it. Just a thought?
UNDER PSI
Nov 1, 2015 09:39 PM
Mackel
Oct 16, 2015 09:03 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Mackel
Sep 29, 2015 02:41 PM
toob
Sep 26, 2015 11:44 AM
