Transponder coil position
Old Feb 7, 2007 | 04:45 PM
davelyoung1's Avatar
From: POETS Somewhere in America not on company time
Default Transponder coil position
What is the transponder coil position on the ignition key. One can look from the dash and look at the silver ring around the ignition key. It has a black mark on the silver ring, I need to know if this mark is on the bottom or top. Or where it is located. I am not sure if the transponder coil has to be in a certain position.
Old Feb 8, 2007 | 01:49 PM
Maxwell's Avatar
Default Re: Transponder coil position
why do you need to know this anyways? you should download the repair manual, it will answer your questions.
Old Feb 8, 2007 | 03:06 PM
scar426's Avatar
Mine is on the bottom seems offset just a tad to the right.
Will
Old Feb 8, 2007 | 04:17 PM
I have the repair manual it does not show how to orient the transponder.
Thanks, I will put mine in with the notch on the transponder ring toward the bottom.
blackpepper
Dec 18, 2021 06:17 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
RED DOG
-C-I-C-C-I Discussion
Oct 8, 2015 09:28 AM
RED DOG
25
Sep 21, 2015 08:46 PM
bobbie
Sep 12, 2015 12:49 PM
