Tire monitor problem
Old Feb 17, 2007 | 08:24 PM
Maxwell's Avatar
Default Tire monitor problem
I'm having an issue with the TPM (tire pressure monitor) light, it won't go out. I brought the car to the dealer for fog lamp glass replacement, when I received the car from them The TPM light was on. So I checked the pressures in the tire and it seems someone at the dealer over inflated them to 42 psi. So I let some air out and to bring it down to 35 psi. I drive around for a week and the light is still on.
Then I figured that maybe I have to reset the computer or something, so I disconnect the battery for an hour and come back to reconnect. After doing so, the ABS/TC system light turns on, but eventually goes out after 3 minutes, but I still have the pesky TPM light on. Do I have to turn the key to run mode, so to drain all battery power from the computers?
Old Feb 20, 2007 | 10:40 AM
Case's Avatar
Default Re: Tire monitor problem
Try 32 psi, that's the pressure i put in any time i get the light.
Old Feb 20, 2007 | 11:02 AM
RPM's Avatar
RPM
Moderator
I use 35 psi and haven't had that problem yet.
I know the TPM light was on in my 4Runner a while back. I checked all 4 tires and they were good. Turns out it was the spare that was low. Of course since the Xfires have no spare - I am of no help to you.
Old Feb 20, 2007 | 11:47 AM
CrossfireLTD's Avatar
Cool Re: Tire monitor problem
This has been discussed before and there are many threads on the subject. Make sure that all tires are at the right pressure (32 psi front & 33 psi rear), the TPMS will only trip when there is at least a 25% loss of pressure. This is what has worked for me in the past, while filling your tires make sure the ignition is in the start position or running. After filling your tires to the proper psi cut the car off and wait about 2 minutes then restart your car and the light should go out.
Old Feb 20, 2007 | 11:56 AM
bobs's Avatar
Sounds to me like one of the batteries in your TPM sensors has gone bad. Your dealer should be able to tell you which one from the fault code. A new TPM sensor costs about $65 if I remember correctly.
PNA
Nov 12, 2020 04:44 PM
Kodebuster
Nov 5, 2020 04:06 PM
nickwe21
39
Jul 31, 2015 01:48 PM
Bifftws
Racing
Jul 28, 2015 05:31 PM
MSCrossfire42
Jul 27, 2015 07:59 PM
