Break in period
Old Aug 3, 2008 | 07:12 PM
ingsoc39's Avatar
Default Break in period
Hello All,new to the forum, i have a new 07 Crossfire Ltd, came with 29 miles on it, Im up to 640 approx, I've been following the manual re the 1000 mile break in period, question, is this sufficient? I've always felt break in was approx 3K on a new car, and hear different things from different car makers, I don't drive too agressively anyway, but still would like to kick the rpm's up and just want to make sure Im doing it when I should, thanks much!
Old Aug 4, 2008 | 02:22 PM
ingsoc39's Avatar
Default Re: Break in period
Anyone??
Old Aug 4, 2008 | 02:49 PM
DesertFox's Avatar
Different strokes for different folks... some will say to break it in for a 1000, others will say to drive it like you stole it for the first 1000 miles...
Old Aug 4, 2008 | 03:57 PM
aschrager's Avatar
If I remember correctly the computer will limit the rpm till you pass the break in period.
Old Aug 4, 2008 | 05:12 PM
+fireamx's Avatar
When I first started using synthetic oil back in 1979, the oil companies literature said not to use their oil until the engine was adequately broke in. But they didn't say exactly when that was. So I wrote to them and asked when should I put their oil into my new 280ZX that I had driven only 2500 miles. They wrote back and told me not to use their product until I had 7k on it.
On a trip to Wisconsin that spring I drove very conservatively on the Interstate on my way up and I checked my gas mileage. Then on the way home I turned over 7k and drove the car quite differently on the way back. While using secondary roads, I drove much harder with a lot of down shifting and upshifting, and holding it in gear longer. I also ran about 10 mph faster every chance I had, and the car seemed to just "loosen up". It also got better mpg.
Now that was nearly 30 years ago, and as we all know, high performance cars come with synthetic oil right from the factory. So how that one simple fact changes the whole equation, I really just don't know.
I suppose the best thing to remember while you have very few miles on your car is to simply alternate your speeds while not "lugging" your engine, or keep from using your high gears until your on the highway at highway speeds. It's better to keep your RPM's up in the lower gears, than it is to get into overdrive at too low of a speed.
I've always been a believer of driving a new car pretty much the way you will always drive it, just don't abuse it, and it should "break-in" OK. I've broke-in about 20 brand new cars since I started driving over 40 years ago, and I've never had one to ever give me any engine trouble, or be an "oil burner". Just enjoy your car, and it should break-in just fine.
Old Aug 4, 2008 | 08:12 PM
ingsoc39's Avatar
Thanks all for the help, I do appreciate it, and will take all abide by the sound advice youve given!
Old Aug 5, 2008 | 05:12 PM
Kurts's Avatar
You should be fine & in the case of this car, following the manual would be the way I'd go. Like +fire says, just drive it !
Old Aug 10, 2008 | 12:28 PM
klamathpro's Avatar
Just drive it. It will eventually break for you. It's a built-in feature on all MB's.
Old Aug 10, 2008 | 01:46 PM
SRT6nTulsa's Avatar
Mine really came alive around 2600 miles. I don't know if the NA is the same way. Cheers.
eikon
Sep 9, 2019 10:16 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
toob
Sep 26, 2015 11:44 AM
Jackobo
Sep 24, 2015 10:21 PM
cppeabody
Sep 15, 2015 08:43 AM
