Dual external wastegates instead of cutouts?
Old Aug 20, 2008 | 12:29 PM
sonoronos's Avatar
Default Dual external wastegates instead of cutouts?
Have any of you SRT6 folks considered using dual external wastegates controlled by vacuum lines instead of cutouts for your exhausts?
Old Aug 20, 2008 | 12:56 PM
Infinite's Avatar
Default Re: Dual external wastegates instead of cutouts?
cutouts work better and are cost effective. The largest gate tial makes is 60mm and they are about 750 a piece
Compare that to the cost of two 3" cutouts
Old Aug 20, 2008 | 01:02 PM
sonoronos's Avatar
Does anyone make pneumatically actuated cutouts? Would anyone like pneumatically actuated cutouts?
Pneumatic means that they stay closed in vacuum and only open in boost, no electricity required.
Old Aug 20, 2008 | 01:18 PM
Infinite's Avatar
ATP makes them
Old Aug 20, 2008 | 02:03 PM
BlUEMDsrt6's Avatar
Hers the link: http://www.atpturbo.com/root/releases/release091004.htm
Very interesting.
Old Aug 20, 2008 | 02:04 PM
Voyager's Avatar
im reading up on the atp one and it looks like it works better with turbos but would run almost all the time with a supercharger right?
Old Aug 21, 2008 | 05:06 AM
sonoronos's Avatar
Looks like it uses a turbo wastegate actuator, so you could play games by using a simple mechanical pressure regulator, restrictor, stronger spring, etc.
Old Aug 22, 2008 | 09:49 AM
Infinite's Avatar
can't change springs actuator is sealed. Regulator would be pointless because those valves open at the first sign of positive pressure
blackpepper
Dec 18, 2021 06:17 PM
waldig
Jul 31, 2017 09:46 AM
minimayhem
16
Aug 23, 2016 07:47 AM
Ralph289
Sep 21, 2015 09:34 PM
RacerXofFL
Sep 15, 2015 05:00 PM
