HELP My car only starts intermittently
Old Dec 2, 2008 | 07:50 AM
queenmum's Avatar
Default HELP My car only starts intermittently
Any suggestions??? My car has been in shop about a month....it will start intermittently....they have replaced the ignition, some brain that works with emissions and a pulse module....
When i go to start it and turn the key either absolutely nothing happens or the car starts.....it doesn't seem to make any difference if it is hot or cold.
Old Dec 2, 2008 | 07:58 AM
Stogey's Avatar
Default Re: HELP My car only starts intermittenlty
Do a Search on Relay Control Module !!!
Old Dec 2, 2008 | 10:47 AM
MikeR's Avatar
Do you get a CEL? If so, what code?
MikeR
Old Dec 2, 2008 | 07:22 PM
queenmum's Avatar
Thanks for the info.....have given it to chrysler service.....sure do hope that this is the answer...and that they will try it....
Old Dec 2, 2008 | 07:25 PM
queenmum's Avatar
What is CEL?? Is this something I should ask the service tech ?
Old Dec 2, 2008 | 07:46 PM
SRT6nTulsa's Avatar
Sorry about the flagrant overuse of forum acronyms. CEL is the "Check Engine Light" for those normal folks out there.
Old Dec 2, 2008 | 08:11 PM
04xfirecoupe's Avatar
It's your RCM it sounds like, search for Relay Control Module. It sends a false note to the computer when it gets hot and skews the solder, causing the computer to think there is no fuel pressure. All the electronics work but it won't start, and it can also die mid-driving just as though it ran out of fuel.
It can be resoldered at the circuit board in no time, and you're not out the $200 bucks it costs from Chrysler/Mercedes.
Old Dec 4, 2008 | 06:26 PM
Okiered's Avatar
This sounds like a problem I've had another car I once owned. It exhibited the same characteristics, and it turned out to be a bad main electrical ground. It's a very simple fix.
Old Dec 4, 2008 | 08:18 PM
tighed1's Avatar
Sounds like it may be one of the common problems I've found on this site. Could be the relay control module.
Go here
https://www.crossfireforum.org/forum/...ad.php?t=27288
Gives the part number and cost. Seems to be cheaper from the MB guys'.
Do a search on "relay control module" and you will see the symptoms are similar to yours.
Good luck, report back if that's it.
Old Dec 18, 2008 | 05:58 PM
queenmum's Avatar
Go here
Got my car back two weeks ago and so far so good.....they did put in a new relay control module after I gave them the info I got from here.....thanks
Old Dec 19, 2008 | 04:40 AM
Stogey's Avatar
Default Re: HELP My car only starts intermittently
Glad we could help Mum !!!
foxy1305
U.K.
Jan 1, 2020 11:41 AM
BEATv1
Jul 16, 2015 09:40 AM
carmax
Jun 18, 2015 01:30 PM
mhajek18
Jun 17, 2015 01:35 PM
gobraves423
Jun 6, 2015 07:03 PM
