Eibach Springs
Old Jul 10, 2003 | 03:31 PM
imported_mightyjlr
Guest
Posts: n/a
Default Eibach Springs
Eibach is currently working on developing lowering springs for the Crossfire. They should be released within a few months. The part number is 2864.140.
Old Jul 11, 2003 | 01:07 AM
mouserider's Avatar
Default
There's quite a bit of height that the Crossfire can afford. I hit things with my 300M that clear fine with the Crossfire.
Something I do appreciate on those nasty driveways and crazy potholes.
Does anyone make height-adjustable hydrolic shocks in the aftermarket? Like the ones they have in the SL55 AMG or the SL500?
Old Jul 11, 2003 | 01:16 PM
krooner's Avatar
Default Re: Eibach Springs
eibach's are good if u just want the car alittle lower and alittle stiffer.. if you want a more performance orientated setup i would wait for h&r to devolp something.. i hated my eibach prokit, way to soft for me..
later..
Old Aug 7, 2003 | 03:38 PM
BlazeRed's Avatar
Default
H&R and Eibach will be about the same. The only difference is that you could go with the cup kit. The problem is the camber would be way off and a camber kit is 1200 dollars from Australia. I can get Carlsson and Brabus springs if anyone needs them. They are exclusively Mercedes but they will fit.
Old Aug 7, 2003 | 03:44 PM
imported_mightyjlr
Guest
Posts: n/a
Default
I'm probably going to go with the RENNtech springs and camber kit. It's $525 for the lowering kit, $495 for the adjustable rear camber and bushings kit, and $555 for the front camber/caster kit. Expensive, but I don't think you can get anything better than that.
Old Aug 8, 2003 | 03:04 AM
krooner's Avatar
Default
I just checked kw's website(company that makes awesome stainless coilovers for european cars, some american cars now also), they have no applications for slk or the crossfire.. they have it for c-classes, e-classes, clks, and sportcoupe(whatever that is) but no slks.. i found that odd.. http://www.kwsuspensions.com/ if anyone wants to check out they're stuff, as they do have other dc applications(pt cruiser, neon, viper).. $525 for the renntech kit is a really good price if its a cup kit (struts/springs, matched for each other), frankly I'm suprised at how good the pricing is..
i dropped 900 for fully adjustable coilover suspension for my car, no regrets whatsoever..
onehundred80
Aug 6, 2016 12:03 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ayebb
Sep 18, 2015 03:35 PM
mattnelson71
Jul 30, 2015 10:49 PM
