Working on the fuel controller
Old Apr 25, 2009 | 12:13 PM
waldig's Avatar
Talking Working on the fuel controller
I wanted to get a better fuel pressure regulator to do the fuel controller for my tunes and needed an adjustable one. Got one nice regulator from Rob and noticed that it wanted double o ring AN style fittings.
Went to try to buy them and found that they are way expensive and ran up to like $25 per port????????? Crap, I just wanna connect ot the regulator and add a barb fitting for the fuel lines...........................Not to do experiments with $75.00 of "you have to order those".
Checked and the fittings were almost 3/8" pipe threads so I bored them out and then tapped the holes to accept the standard low ego fittings. ITs a Car.
If you have not had the opportunity to do this type of thing , heres a few shots of the work that is needed. The Right end of the block is threaded with the 3/8" thread. The left side is the original NON tapered thread for the AN fittings. You can also see the tap I used and what a tap is, makes female threads.
Enjoy the weekend, Woody
Old Jul 16, 2009 | 08:17 PM
Dave Rockwell's Avatar
Default Re: Working on the fuel controller
Do you have any photos of the new regulator installed......with all the hoses in place?????
I am doing the same thing not sure of the hose replacement
Thanks Dave
BrenLW
Aug 5, 2015 04:53 AM
crymar
Jul 17, 2015 08:46 AM
Adrian_X
Jul 12, 2015 11:05 PM
ja.nko
Jul 10, 2015 03:21 PM
bdh
Jul 9, 2015 09:40 AM
