Looking for speed pulse wire
Old Aug 9, 2003 | 10:07 PM
biggjay's Avatar
Default Looking for speed pulse wire
Can anyone tell me the factory color and location of the speed pulse on this car,,,,,I am trying to install an aftermarket navigation and need this info...
Thankssssss
Old Aug 9, 2003 | 10:10 PM
imported_mightyjlr
Guest
Posts: n/a
Default
Sorry, I can't help you. There is at least one member on this forum with the service manuals though who might be able to help. Hopefully they will see this post. I would suggest calling the dealer and asking, I'm sure they would be able to tell you. Post pictures if you can when it is finished... I would love to see how this looks.
Old Aug 10, 2003 | 03:26 PM
texex91's Avatar
Default
What kind of aftermarket are you putting in??
Old Aug 10, 2003 | 03:33 PM
biggjay's Avatar
Default speed pulse wire
Alpine navigation with dvd player and monitor
Old Aug 10, 2003 | 05:38 PM
biggjay's Avatar
Default
I've got some pictures so if your interested shoot me your email and I will send them,,,,,btw this is probably one of the best put together cars that I've seen come out in a while,,,,,,,someone took some time when they designed this vehicle....
Old Aug 10, 2003 | 05:46 PM
imported_mightyjlr
Guest
Posts: n/a
Default
Would you be able to post them? You get your own Personal Gallery when you register to this forum, to put as many pictures in as you want to. Here are the directions to upload to it:
https://www.crossfireforum.org/forum/viewtopic.php?t=82
Old Aug 10, 2003 | 06:23 PM
texex91's Avatar
Default
Did you have to replace the amp and speakers? I was told you would have to if you replace the head unit. Also, please do post the pics!
Old Aug 10, 2003 | 06:58 PM
biggjay's Avatar
Default
No need to replace amps and speakers, everything is a 4ohm impedance....you must have spoken with a saleperson who didnt know what they were talking about,,,,,kinda of wierd config. radio says infinity but harness is from a blaupunkt....easy install,,,,just finished our first one and came out great,,,,,,,,
Old Aug 10, 2003 | 07:40 PM
texex91's Avatar
Default
Actually it was two different installers told me that due to the config everything had to be replaced--is that not the case? Could I replace the head unit with an Alpine and not anything else??? Which unit did you install?
Please post the pics for everyone in your "personal gallery".
Old Aug 10, 2003 | 07:49 PM
biggjay's Avatar
Default
I did an IVA-D900 plus a navigation system let me kow if you need one I will give a hell of a deal
Old Aug 12, 2003 | 12:02 AM
TRANNY-MAN's Avatar
Default
biggjay
Which wires are you looking for?
Old Aug 12, 2003 | 12:53 AM
biggjay's Avatar
Default speed pulse
Looking for either a digital or analog speed pulse wire from the ccm or the pcm color and location would be perfect
Thanks
Old Aug 12, 2003 | 01:29 AM
TRANNY-MAN's Avatar
Default
PM me your email address and I will send you a wiring diagram.
Old Aug 12, 2003 | 03:08 PM
biggjay's Avatar
Default
Looking for the ccm and a diagram if you have it
Old Aug 13, 2003 | 03:04 AM
biggjay's Avatar
Default
Thanks Tranny-Man just for future reference if anyone ask the speed pulse wire is dark grey with a white tracer located at the factory amplifier,,,,thanks again you saved the day
Old Aug 21, 2003 | 11:09 PM
X-fired's Avatar
Default
Just curious... I have the shop manual and am looking at the the audio schematic. Why does the wheel speed sensor signal go to the radio and amplifier?
Biggjay - I'm assuming you used the amp-on output from the head unit to turn the antenna on. Correct? Did you need to add a relay?
Thanks.
Old Aug 22, 2003 | 12:07 AM
TRANNY-MAN's Avatar
Default
The audio amplifier recieves a vehicle speed signal from the CAB ( controller antilock brakes) that allows the amplifier to adjust the audio output as vehicle speed changes. The faster you drive the more road noise you get the volume gets slightly louder.
Old Aug 22, 2003 | 04:49 PM
mouserider's Avatar
Default
Absolutely.
The Infinity Modulus has a speed-dependant volume system so it does need to know what speed the vehicle is going.
Pretty nice feature but it freaked me out the first time as I didn't read about the feature.
Old Aug 22, 2003 | 06:11 PM
texex91's Avatar
Default
Tranny:
What do you have a wiring diagram of??
Old Aug 22, 2003 | 11:30 PM
TRANNY-MAN's Avatar
Default
I have the complete wiring diagram. Let me know what area you are looking for and I will email it to you.
