Mod questions
Old Feb 11, 2012 | 08:19 PM
radmanly's Avatar
Default Re: Mod questions
Thanks for the quick reply. Do you have a picture of what it should look like? And what's the clearance between your MAF housing and the firewall?
Old Feb 11, 2012 | 09:11 PM
radmanly's Avatar
I pulled everything apart and discovered that I was actually grinding off metal shavings from the MAF housing against the throttle body. It's not going down any further.
Old Feb 12, 2012 | 12:32 AM
radmanly's Avatar
I put everything back together and finished the install. The MAF housing still isn't clearing the firewall as I would like but it doesn't seem to hurt anything. I reconnected the battery and did a throttle reset. The car started right up. I took it around the block and it drove fine. I rechecked all of the connections when I got home and everything is still nice and tight. So far, so good.
Next up...ECU tune.
Old Feb 12, 2012 | 10:07 AM
A wee bit of vaseline wouldn't hurt, that's what I used, however,
I have the OLD NW CAI that has only the 90 degree coupling from the 74mm TB to the aluminum intake tube.
The MAF sensor is mounted in a weld-on bung in the intake tube, there are no clearance problems.
Rob says this older version does not have quite the flow numbers as the new one, but it is a heck of a lot easier to install .......
(excuse the picture quality - cell phone )
Old Feb 12, 2012 | 10:52 AM
radmanly's Avatar
Thanks for the pic. You definitely have more clearance than I do. I wiggled and wrestled with it a little more, but after discovering I was actually grinding metal off the bottom lip of the MAF housing against the TB inside the coupler, I decided to stop. My MAF housing is still touching the firewall but it hasn't caused any problems yet.
Here's the completed install:
Old Feb 12, 2012 | 01:14 PM
NeedsWings's Avatar
im not sure why your MAF housing is so close to the firewall but i can make you up another maf housing that is slightly shorter on that end and we can swap them out, please shoot me an email directly.
triplmmm
Sep 24, 2015 12:12 AM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
waldig
Sep 17, 2015 10:35 AM
Bill F
South Forum
Sep 11, 2015 02:29 PM
brandoni
Sep 10, 2015 02:11 PM
