OEM Wheel Mod.
Old Aug 22, 2004 | 06:38 PM
HDDP's Avatar
Default OEM Wheel Mod.
Here's the wheel modification I was talking about a few weeks ago... Powder Coated "graphite" to match the grapite color on the OEM grill...
Old Aug 22, 2004 | 08:47 PM
drunkiq's Avatar
Default
You lost me a little (keep in mind I am color blind). you are matching the wheels on the side of the car to match the greyish??? grill on the front??? of the car?
I am a little confused as to what item you are trying to match. If the item is not on the side of the car then it won't make sense from the side or rear quarter views and will only match the car from a front corner views...
-marc
Disclaimer: This post is intended for the use of the individuals which have rights to view this thread and may contain information that is confidential, privileged or unsuitable for overly sensitive persons with low self-esteem or lack a sense of humor. If you are not one of the intended audience , then any dissemination, distribution or copying of this post is not authorized (either explicitly or implicitly) and constitutes an irritating social faux pas. Unless the word absquatulation has been used in its correct context somewhere other than in this warning, it does not have any legal or grammatical use and may be ignored. No Crossfires were harmed in the transmission of this post. Those of you with an overwhelming fear of the unknown will be gratified to learn that there is no hidden message revealed by reading this disclaimer backwards. However, by pouring a complete circle of salt around yourself and your computer you can ensure that no harm befalls you and your Crossfire. If you have read this post in error then please add some nutmeg in egg whites and place them in a warm oven for 40 minutes. Whisk briefly and let it stand for two hours before icing.
Old Aug 22, 2004 | 09:08 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default
i believe he is referring to the gray plastic part of the front grill.
my question is...are the rims photoshopped or have they truly been painted and this is a picture of the real thing?
i think it looks cool on the black....nice job! thats one spotless black crossfire.
Old Aug 22, 2004 | 11:00 PM
HDDP's Avatar
Default
The spoke color matches the darker graphite metallic on the front plastic grill. The powder coat colors that match are called "Iron Glimmer P7", and the remaining silver on our car is called "Bavarian Silver".
This is photoshopped as the powder coater needs the wheels for a week and the car will be going up on blocks on Wednesday so they can remove the wheels and tires to powdercoat them this way...
I wanted to see the entire wheel mod. before I committed to it...
Old Aug 23, 2004 | 12:21 AM
David Burns's Avatar
Default
If I were going to do what you've photoshop'd, I'd do it in black to match the car. I think that would be a better contrast, and give it something to match.
Old Aug 23, 2004 | 10:18 AM
NJspeed69's Avatar
Default
I think those wheels look hot as hell.
Old Aug 23, 2004 | 10:54 AM
drunkiq's Avatar
Default
ditto on the black - there is not enough of the gray on the side of the car the make the accent of they graphite work well. It would be like making them red to match the platic lenses in the rear. Of course I am color blind so I could be wrong.
-marc
Old Aug 23, 2004 | 12:30 PM
Dan Root's Avatar
Banned
Default
Say Dereck i know you may want the Powder coat but I do know a mobile guy that will paint your wheels in one day and do it on the car !about 125 a wheel.And if you ever need touch up he can repair them later!#Rob,6613733232,he also does stock wheel repairs.He did 2 of my jag mags came out like new.On the car!
Old Aug 23, 2004 | 04:11 PM
Guest
Guest
Posts: n/a
Default
I thought about getting the centre troughs in the spokes done in graphite to match my graphite car. Think that would look nice.
The above looks alittle out of place IMO, just doesn't tie in with anything else on the side ... sorry
Old Aug 23, 2004 | 04:42 PM
RGT's Avatar
RGT
Default
I think they look good.
Matt
Old Aug 23, 2004 | 05:39 PM
aaaaa5star's Avatar
Default
those look excellent, what did that set you back?
livefreeordie
Sep 22, 2015 08:13 PM
cdcrone123
Sep 20, 2015 10:02 PM
Idrenak
Sep 19, 2015 08:17 PM
caseydeankopp
Sep 13, 2015 07:25 PM
81's
Sep 13, 2015 04:34 PM
