CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   Troubleshooting & Technical Questions & Modifications (https://www.crossfireforum.org/forum/troubleshooting-technical-questions-modifications/)
-   -   Key won't turn in the ignition.... (https://www.crossfireforum.org/forum/troubleshooting-technical-questions-modifications/6054-key-wont-turn-ignition.html)
GoodEnough Sep 2, 2004 06:09 PM
Have you had problems with your ignition?
Bought my new '04 this last Saturday, 48 hours later my key(s) wouldn't turn in the ignition. I am told that the igntion assembly, steering column, housing & other parts have to be replaced. The parts have to come off the assembly line & will take at least a week to get to LA, CA.
SCORE: ME=48 hours. THEM= 11+days.
Not to mention that Chrysler's Roadside Service tow guy ran the front end of my car into the driveway at the dealership. I also found scratches around the entire car. Now I have a claim with the Roadside Service folks.
It will have to go to the paint & body shop after it finally gets fixed.
SCORE: ME=48 hours. THEM=18+ days.
Stay tuned for final score.
jmackinjersey Sep 8, 2004 12:12 AM
did you get the problem fixed? Sounds like you need to turn (wiggle) the steering wheel a little before you try to turn the key. I had a simular problem and that simple little thing fixed the problem.
Does it happen with both keys?
catman Sep 8, 2004 11:45 AM
Key wouldn't turn in the ignition...
I agree with jmackinjersey for the fix. I had the same problem and just turned the steering wheel to take the tension off of the key.
x'ed Sep 8, 2004 01:08 PM
yeah when the steering wheel locks on benzos you have to wiggle the steering wheel to start them. not sure if that is how our car works to......
X-fired Sep 8, 2004 06:06 PM
I've had similar problems with my ignition - but only temporary and intermittent. My problem is NOT because of tension on the steering wheel. I can be flat and level, no tension in steering wheel and the ignition won't turn until I keep wiggling the key (not the steering wheel) while attempting to turn it. I'm afraid I'll get stranded some day.
I posted this a few weeks ago and only got the "steering wheel" comments. I've had other cars where you can't turn the key with tension in steering wheel - this is different.
Let us know how the fix goes.
© 2026 MH Sub I, LLC dba Internet Brands
