Are there any screws here?
I was wondering if any of you with automatics know if there are any screws that are supposed to be holding the plastic with the P-R-N-D on it...mine is loose and moves left-right as I move the shifter...
I just had my console out but did not look, however it's easy to just pop the silver pieces out and look. All it takes is a plastic trim removal tool, Harbor Freight sell a set for about $7. It definitely should not be moving.
I had mine apart to fix a window switch...I've noticed that it moved, and I thought it shouldn't...just wondering what screws to use!
RiderJC
Aug 14, 2015 07:53 PM
