flaps do not retract when closing top
Old Jul 14, 2014 | 05:57 PM
JamesCraft's Avatar
Default flaps do not retract when closing top
the flaps do not retract When closing the convertable top, i have to manually hold the flaps back to close the top, what should i look for?
Old Jul 14, 2014 | 06:38 PM
Default Re: flaps do not retract when closing top
The flaps are spring loaded to fold in when you put the top UP, and forced to extend by the cables when you put the top DOWN.
If they aren't folding in, then there is a bind in the flap swivel point or the cable.
The cables are very hard to lubricate, you can try drizzling some lubricant in and let gravity do the trick, or you can completely remove the cables and soak them overnight in lubricant.
Consult your local motorcycle / bicycle shop, they might have some better tips on cable lubrication.
Here's a good solution :
http://www.jpcycles.com/product/9100...FQYoaQodoqEAXg
Old Jul 14, 2014 | 06:43 PM
Abaton6's Avatar
If it's the cables, try this,....
Amazon.com: American Grease Stick LE-4 Lock-Ease Graphited Lock Lubricating Fluid 4 fl.oz bottle: Automotive Amazon.com: American Grease Stick LE-4 Lock-Ease Graphited Lock Lubricating Fluid 4 fl.oz bottle: Automotive
I've been using it in my cables for years.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 25, 2015 02:16 AM
