Used TCM Need Reprogramming or Not?
Old Dec 29, 2014 | 12:46 PM
crymar's Avatar
Default Used TCM Need Reprogramming or Not?
I bought a used transmission control module which I plan to install in my 2004 Coupe. The used TCM I bought is also from a 2004 Coupe. Does this TCM need reprogramming before it will work? I've been through all the threads on the TCM and there are both "yes" and "no" answers. It seems to work without programming for some and not for others. Can someone straighten this out? Also, my factory manual says there is a "Quick Learn" procedure that requires a special scan tool. However, does the term "Quick Learn" mean that the there is also a "slow learn" procedure that doesn't require the scan tool, but just a certain number of driving cycles?
Old Dec 29, 2014 | 06:54 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Used TCM Need Reprogramming or Not?
Short answer is NO. No programing is required if the new TCM came out of a working car of the same elk as yours.....example NA to NA or SRT6 into a SRT6
I have a spare tuned SRT6 TCM that can moved between other SRT6 's.
Old Jan 6, 2015 | 12:55 PM
crymar's Avatar
Thanks for the reply. Checked with a local MB shop and they said the same thing.
Old Jan 8, 2015 | 07:58 AM
Sweet2002's Avatar
There is a reset function that some swear by but basically the TCU will "learn" your driving habits and if you drive it more aggressivly the tranny will respond in like manner. baby it and it may become a bit sluggish.
Abaton6
Oct 26, 2016 10:43 AM
crossfireusa
Oct 28, 2015 12:03 AM
jimf
19
Oct 19, 2015 04:05 PM
UrbanE
Jul 16, 2015 01:39 AM
Fildo Dog
Jul 6, 2015 05:20 PM
