CEL after unplugging Amp
Old Jun 6, 2015 | 06:38 PM
eastside08's Avatar
Default CEL after unplugging Amp
So i recently had a check engine light that came on. One PO410 and PO730. Its weird became it didnt come on until after i pulled one plug from my amp under the passenger seat. The codes went away after i disconnected the battery for about 5mins. Anyone know what could of caused this issue?
Old Jun 7, 2015 | 01:33 AM
KDW4Him's Avatar
Default Re: CEL after unplugging Amp
0410 is the smog pump, not sure of the other code without looking it up. You sure it was the amp you unplugged? Could you have bumped other connections?
Old Jun 7, 2015 | 12:07 PM
eastside08's Avatar
I'm sure it was the amp.the CEL has yet to come back on so I think it's fine.
Old Jun 7, 2015 | 07:21 PM
This is one wild guess, it sounds like you may be backfeeding a ground through the amp ground somewhere else that is either corroded or cut. If you remove that ground (by pulling the amp plug), then the sensor giving you the code doesn't have a ground, hence the code. If this is your problem, you'll have to manually trace all the ground points associated with the smog pump (and the other code) systems and see where they converge with the amp ground/connectors. One other wild guess, you have some chaffing of wires going on and that will be a big headach to sort out. Good luck!
pioneer4x4
Mar 18, 2021 02:17 PM
Sterling57
Apr 11, 2016 06:11 PM
mobilefitt
Sep 24, 2015 01:04 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
81's
Sep 13, 2015 04:34 PM
