Building Ford 9" set up
Old Jul 7, 2015 | 07:34 AM
Default Building Ford 9" set up
Ford 9" rear end,, into my car
I have decided to be the one to go this way, . some may want it also. so here is the info as of today.
I don;t know the cost at this time, but it can't be more than installing a V8 LOL
at this time I am building ONE, before it is finished ,if there is interest, please let me know as that could bring my cost down, and asap i could let everyone know what it will cost to own.
I look at it this was the Wave trac was 1200.00 and all you got was a limited slip.
The kit is going to consist of Ford 9" rear,, axles made to fit into your crossfire and withstand 1000+ hp,,,a one piece drive shaft with U-joint at the rear.
special spider gears in a Ford 9" pumpkin
either alum or carbon fiber drive shaft,
any gear set you want from 2.37 to 6.77
limited slip center section, detroit locker, spool or open rear.
and a tcu so it all works on your car.
Old Jul 7, 2015 | 08:04 AM
gblack32's Avatar
Default Re: Building Ford 9" set up
Subscribed and thank you again amx for being a pioneer.
Old Nov 18, 2015 | 06:29 AM
ImportLabSRT's Avatar
Any progress, Jim? I would normally say that this would be a winter project, but you do not quite get "winter" in Florida.
Old Nov 18, 2015 | 08:21 AM
yes ,the 9" has arrived, not the perfect fit into the subframe , so it went back for modification, looks like ,it is going to work .jim
Old Nov 18, 2015 | 08:31 AM
Very nice! I cannot wait to see the finished product. You truly have the baddest Crossfire on the planet!
Old Nov 18, 2015 | 08:43 AM
thank you,, I only have fun and share the info. years ago i said, most people say a car is something to go from point to point,, I say the car is the point. then about 3 years ago Jessie James said almost the same thing on TV so JJ gets the credit,, he said people think a car is to go from point to point, I think the car is the point JJ. jim
Old Jan 19, 2016 | 06:14 AM
Any updates, Jim?
I am still mulling around the idea of a 6spd and I know any stock replacement rear end will not fair well.
Old Jan 19, 2016 | 08:11 AM
Any updates, Jim?
We, Rudy and I had to abandoned the ford 9" because of the cost , u had to buy a special housing for around 2000, the gears around 400, the axles for around 500 each and the R & D would cost us over 10000.
So I am doing a 3.46 Mercedes diff set up for the Crossfire for 3780, supply your diff and tcu get 500 core back,,, now for the 6 speed it is 5 or 6 hundred less because u don'r need a tcu ,,but have to look at my price sheet to be sure of the prices as i am not at home this week,, Oh, this is with a new wave trac but if u if you have one it is 1250 less again. lf u are interested in a 3.27,,3.46,, or for those people that wanr it,,with 6 speed we can do a 2.89 jim
Old Jan 19, 2016 | 08:15 AM
I had to abandoned the ford 9" because of the cost , u had to buy the housing for around 2000, the gears around 400, the axles for around 500 each
So I am doing a 3.46 Mercedes diff set up for the Crossfire for 3780, supply your diff and tcu get 500 core back,,, now for the 6 speed it is 5 or 6 hundred less ,, have to look at my price sheet,, this is with a new wave trac so if you have one it is 1250 less again. will add to this soon as have ro go for now jim
I already have a wavetrac in my current diff.... Does the 3.46 use a different housing and bigger pinion? I am sick of breaking pinion gears.
Old Jan 19, 2016 | 08:51 AM
it is a different housing I think,,checking with Rudy on that, but it does bolt up into the crossfire subframe . from my memory the pinion would be smaller but stronger,, where are you braking them ,,, the teeth or the shaft. jim
pm sent
Old Jan 19, 2016 | 11:15 AM
Padgett's Avatar
BTW people may have talked about Point to Point. I could do that with a '73 Vega GT (had a few, liked them). JJ said the car is the point. I disagree with that also unless it is a coffee table. The key for me as BL said is to travel "with style".
Old Jan 24, 2016 | 02:12 PM
Jim...sent you a PM. Hope you are doing fine. Get with me when you have time. I have already spoke with Rudy. Sunday's are best for me. On the road most of the week. Get well buddy.
Valk
Jul 12, 2021 09:49 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
ozkancab
Sep 25, 2015 10:55 AM
Sep 25, 2015 07:46 AM
Sep 25, 2015 02:16 AM
